    Jun 2012
    Hi everyone, I'm trying to test an application on android and it isn't working right and I'm worried that my videos might be the problem. So I'm looking for a place where I can download some 1024x600 videos I can use for testing. The site says I can use any of these video formats:
    - FLV
    - WMV
    - H.264
    - MOV
    - 3GP
    - AVI
    - ASF
    - MPEG 1, 2 and 4
    - DivX
    Thanks a bunch in advance
  2. And that site is what? Do they have a contact email? If you got the app from that site don't they support it?
  3. I doubt you'll ever find a 1024x600 video to download because at 1.71:1 it's an unheard of ratio. Can't you make one yourself? Resize and reencode something you already have?
  4. Member DB83's Avatar
    Jul 2007
    That smells like the screen dimensions of the device. Such as this one:-
    http://www.merimobiles.com/HAIPAD_i7_T_IPS_1024_600_Multitouch_Screen_with_An_p/meri4436.htm
    Nowt to do with the dimensions of the video it displays.
  5. Member Cornucopia's Avatar
    It's probably NOT an oxymoron (what I though at first). More likely bad tech specs reporting.
    If it's like DB83's link, that ACCEPTS 1080p (p-what? 24, 30, 60? probably 30) and 720p30 and 480p30. And then does a resize to full screen (1024x600) with windowboxing or pillarboxing, as needed.
    Yeah, it would be rare to get a clip directly coded for that device (but not impossible). Even then, you don't know if the device is doing other processing when showing fullscreen...
  6. I don't know if it will help but here's a 1024x600 Divx/MP3 AVI file.
    Jun 2012
    Awesome thank you jagabo, just what I needed. Yeah the reason I wanted to download a video was to see whether or not my videos are corrupt cause I'm using free software on a crappy laptop. I'll reply with my results just for the heck of it. Thanks for the replies!
