    Mar 2012
    Romania, Europa
    Hi !
    I also have this problem an almost every video converted with VidCoder (app basedon handbrake). The pixeled image appers at the begining of the video.
    An Example here:
    Original Video Image:
    http://s18.postimage.org/h4n6rwi8p/Original_File.png
    Converted Video Image:
    http://s19.postimage.org/uhezim6k3/Connverted_File.png
    I made some screenshoots of my settings:
    http://postimage.org/image/rbzfpiu9b/
    http://postimage.org/image/y3pusdj8v/
    http://postimage.org/image/qc94ttf3j/
    http://postimage.org/image/c73bs0627/
    http://postimage.org/image/on01lqze7/
    http://postimage.org/image/n1krtxp67/
    Log Verbosity level is 2.
    Here is the Log: (text or image)
    http://dl.dropbox.com/u/26133258/LOG.Verbosity.2.txt
    http://s19.postimage.org/58z7m27xv/Log.png
    Here you can download orignal file if you want.:
    http://dl.dropbox.com/u/26133258/%5BHD%5D%20%5BEnglish%5D%20Happy%20Feet%20-%20%20Some...0To%20Love.vob
    Please help me. I also tried with 2 pass encoding and it's exactly the same output, i tried to change video filters, and nothing happend.
    I also tried lower resolution , and nothing changed.
    As an test i converted the original file with Format Factory to mp4 (H264, 1920x1080, 5000kb, 2 pass) and there is no pixeled image. The output is perfect. Please Help!!!!
    Havee you tried with different x264 profile and presets? Under video and x264 basic settings.
  3. Those are encoding or decoding errors, not artifacts from bad compression settings. Since you've tried several different options, the software is probably having problems reading the source video and getting those block errors.
    Mar 2012
    Romania, Europa
    Hi! Thanks to all for your help!
    I've tried with different x264 presets and profiles, and nothing.
    But i tested MediaCoder, with his codec, and the output quality is perfect (no pixeled image). Thanks for help!
