hi hope this is the right place.
i have long computer with following spec;
Amd 3400+
2 Gb ram
500 HDD
Msi- 7228 motherboard with built in graphic and sound.
i dont have any other card for graphic or sound.
now when i play 720p i have no problem in watching it properly. but whenever i download any movie file of 1080p whether it is 1.0Gb or 4 Gb, it freezes alot and skip screens as well.
is they any way i can play it using my existing system.
Results 1 to 13 of 13
Is this a dual core cpu? If its not dual core you will have problems.
Also chances are motherboard graphics aren't up to the task for 1080p.
You could easily get a graphics card with h264 support that will take the load off the cpu and process it much more easily.
However your main bottle neck will be the processor. I'm just not sure how feasible it is to do 1080p on a single core pc.
I would search for a test program that determines if you can play bluray properly. That would indicate if you can do 1080p. I think powerdvd has one. I'll see if i can dig up a link for you.
Edit - http://www.cyberlink.com/prog/bd-support/diagnosis.do
That is a link for the bluray advisor program they have. I'd take it with a little grain of salt as this would probably be for an ideal + setup and a slightly lower configuration may do 1080p just fine but they may want to push you to a more powerful setup.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If your playing software supports setup for memory cache for local files or streams, use it. You didn't say what you were using.
VLC used to support caching settings but the newer ones don't ... I think that's pretty dumb, I wouldn't use a player that didn't have it. At least for video ... I do use vlc for audio.
SMPlayer, which is what I almost always use for video, does support it. I set the local file stream to 8192Kb, for geeky reasons.
I'm not 100% sure that would work for you but caching can really help. -
AMD Turion 1.6GHZ (on my old laptop) did not play for me
Core2Duo 2.0 GHZ played 1080p with more than 90% CPU
Both with 2GB RAM.
Even CQ56 plays well with a HD GPU. -
thank all for the help.
it is AMD Athlon 3400+.
i was playing 1080p movies in vlc which given me the problem. but strangely when i download windows media player cinema version it was much much better, hardly notice the freezes of the video but the audio sometimes skips ahead.
but with the windows media player i had the issues that i could not turn the audio from stereo to 5.1 in a second like i do in vlc.
i will try smplayer as well.
also since the board and processor are so old i cant find any graphic card here to use it. i use the built in audio and graphic card which i update from nvidia -
smplayer also played just like windows media player but both have this issues.
cant change the bright, contrast while watching the movie as VLC have it
and increasing the volume more higher as VLC.
but did found 5.1 and stereo in smplayer. if any idea how i can change the brightness and contrast just like vlc and other function i might go for it -
While a multi-core CPU is best you can get yourself a videocard with a better GPU(GTX series), that way it will use hardware acceleration.
Yes, that motheboard appears to have a PCI-E 16 slot. An inexpensive graphics card capable of h.264 decoding (DXVA) will allow most 1080p content to play. 1080p 24, 25, and 30 fps will usually work. 50 or 60 fps may not.
An old Windows XP Pentium Pro PC at 3 Ghz with a NVIDIA GeForce GT 430 video card in the PCe slot works fine for 1080p. Media Player Classic Home Cinema works best for me when watching 1080p although other players usually work OK also.
once i restarted my system, it seems that i did not to ret the stream cache since the movie is now working smoothly in smplayer and even in window media player cinema and umplayer as well.
and when i reset the setting of vlc to default the stream improve alot but still freezes now and then.
okay i found the equalizer, but when i tried to increase or decrease them it took no effect on the movie while watching it. any idea why or should i reinstall it?
As now my system is playing the format of 1080p smoothly i dont need the graphic card. i believe the max fps i have download are not more than 24 to 30. guess the 50 fps will be around 10gb size. i just dont go over 2 Gb size. whether for 720p or 1080p
And thank you all for your help
Video Converter Support 1080P?
By cccf25 in forum Video ConversionReplies: 8Last Post: 1st Feb 2012, 00:15 -
1080p(laptop to tv question(s))
By ariesstyles1 in forum Software PlayingReplies: 1Last Post: 5th Mar 2011, 21:23 -
Video lags when playing 720p or 1080p videos without DXVA support
By white_snake in forum Software PlayingReplies: 11Last Post: 28th Nov 2010, 07:11 -
New Philips Upscaling DVD Player DVP5982/37 1080P! and USB 2.0 Support?
By bobsolo in forum DVD & Blu-ray PlayersReplies: 209Last Post: 8th Dec 2008, 15:22 -
720P or 1080p at 32" - that is the question
By guns1inger in forum DVB / IPTVReplies: 27Last Post: 5th Aug 2008, 06:07
