Yeah, I've got plenty of old discs that run and rip perfectly too. Although unlike you I seem to be able to copy them using Windows as fast as I can rip them.
There's a difference between a bad burn (unreadable) and a poor quality burn. I get the odd bad burn too, but I also weed out the low quality ones. I don't always burn at maximum speed. Having run lots of burn quality tests, I know some of my older Pioneer burners burn to Verbatim better at 12x, while the newer ones burn just as well at 16x or more. The Samsung burner doesn't do well with Verbatim DVD+R, but it comes close to matching the Pioneers with DVD-R. I usually don't bother checking the DVDs I burn for other people. Like you when it's for someone else, whatever the quality, it's good enough. Most of the discs I burn are for myself though, so I do check them. If every disc I burned was the same quality, why would I keep running a burn quality test each time? Think about it.....
Results 31 to 33 of 33
To all posters: Please keep your discussions civil and on topic or this thread will be locked.
Moderator redwudz
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 18:18 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 18:55 -
Want to copy a DVD to external Hard Drive
By bwm258 in forum DVD RippingReplies: 9Last Post: 29th Jul 2009, 01:22 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Copy/Paste DVD to hard drive?
By jason in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 15:35
