I have been reading about the settings (https://forum.videohelp.com/forums/10-Capturing), and I think I have it mostly figured out. Thought I'd post here to get it right the first time.
So from what I understand, avi type 2 is better for most editing programs. I was thinking of having the discontinuity threshold at 0, for one large file (I was thinking of doing a second capture, timecode separated files using the alternate avi type 1 to have both). Max avi size 115000 as per the webpage linked. Every Nth frame, 1. And is the checkbox next to capture for winDV to control the camcorder? Thanks!
Type2 covers both. It adds a separate copy audio track.
A good tutorial
http://www.windowsmoviemakers.net/PapaJohn/61/WinDV.aspx
Camcorder control will pre-roll the camcorder. This should not be checked for live capture.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 17:23 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 04:36 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2008, 23:43 -
Windv Scheduler
By ScottEslick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2008, 21:46 -
Error with WinDV ?
By Zhuge Liang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Jul 2007, 02:47
