I'll post the file info of two mkv's that play just fine and one that doesn't, please identify the difference between these files and what causes my problem. What can I do to get my file playing?
Working file 1
General
Unique ID : 193868648759238703890425341818397076002 (0x91D9BE5C1126D6FC9AFB087D2AB52A22)
Complete name : F:\Films\The Fighter\The Fighter.mkv
Format : Matroska
Format version : Version 2
File size : 6.56 GiB
Duration : 1h 55mn
Overall bit rate : 8 122 Kbps
Encoded date : UTC 2011-03-06 10:36:52
Writing application : mkvmerge v4.5.0 ('Speed of Light') built on Feb 1 2011 02:10:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 55mn
Bit rate : 6 610 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.402
Stream size : 5.21 GiB (79%)
Writing library : x264 core 114 r1913 5fd3dce
Working file 2
General
Unique ID : 190075243181011377824770949883760196763 (0x8EFF29065582B025B010F9EBFFA7BC9B)
Complete name : F:\Films\J. Edgar\J. Edgar.mkv
Format : Matroska
File size : 5.47 GiB
Duration : 2h 16mn
Overall bit rate : 5 717 Kbps
Encoded date : UTC 2012-02-10 23:58:19
Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Duration : 2h 16mn
Bit rate : 4 208 Kbps
Height : 536 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.256
Stream size : 3.91 GiB (72%)
Writing library : x264 core 120 r2164 da19765
Not working file
General
Unique ID : 189828412414888510964271842546594111736 (0x8ECF9F5411843DF0AAA9F6FB97E460F8)
Complete name : C:\Users\koen\Vuze\Tinker.Tailor.Soldier.Spy.2011. 720p.BluRay.x264-iNFAMOUS\inf-ttss720p.mkv
Format : Matroska
Duration : 2h 7mn
Overall bit rate : 7 369 Kbps
Encoded date : UTC 2012-01-12 23:29:31
Writing application : mkvmerge v5.1.0 ('And so it goes') built on Nov 28 2011 23:58:28
Video
Format : AVC
Muxing mode : Header stripping
Duration : 2h 7mn
Bit rate : 6 604 Kbps
Height : 544 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.396
Stream size : 5.75 GiB (88%)
Writing library : x264 core 120 r2120 0c7dab9
I read that it could be that files made with makemkv 4.0.0 won't play but this is obviously not the problem. I tried to convert to mp4 with Handbrake which worked but left me with 2 ch audio.
Please help!
Closed Thread
it's usually the dopey header stripping. you can remux the video without header stripping with mkvmergegui. just go into it's options and make sure header stripping is turned off before using it on the video.
start mkvmergegui, open the non-working mkv, give it a new destination or name, click merge. it will be re-written.--
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 19th Jul 2010, 00:26 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10 -
Can a playstation 2 play mkv files??
By goodvash in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 08:00
