Hi everyone.
I own 2 WDTV players (a 1st gen one, and a WTDV Live Plus). I have a large amount of data (crucially, greater than 4 TB). I'd like to connect all my data simultaneously to one of my players, but each has only 2 USB ports, and neither recognize drives over 2 TB. I'd prefer to avoid using a network, and just connect drives locally.
The couple of multi-port USB "splitters" I've used haven't been recognized by either system.
I was wondering - is there a way to do this with these devices? I'm not averse to acquiring another device - is there a similar one with more than 2 USB ports or that can recognize 3 TB drives?
Thanks very much for your help!
Results 1 to 10 of 10
Why not use a NAS to serve the media to your player? Something like this:
http://www.synology.com/products/product.php?product_name=DS212j&lang=uk
I've been using one for a couple of years and love it.
Thanks for the quick response! If at all possible, I'd like to avoid setting up a network. I have to admit, I've looked into NAS before and it looks great, but I'm putting a premium on simplicity here, if it is possible. If the USB connections aren't possible, obviously I'll have to try something else, but I'm hoping I can get them to work out.
Micca ep350
go to avsforum and you'll see in the ep350 thread that this model handles internal and external storage quite well...with very few hiccups -
Thanks for the reference, Micca EP350 looks great. I see that you can put a big internal drive in it, which is awesome. Do you happen to know if it can read external drives greater than 2 TB via its USB connections?
Yeah it's a little known media player but it is far less buggy than any WD model and it basically does it all with no hassles. And it's cheaper
go here and read the entire 350 thread...or google ep350 3tb or size you want to see that thread and see if any other users do what you want it to do -
Partition your 3GB drive into two partitions. I have mine set up as 2TB & 1TB.
My WDTV Live Plus shows the the first partition as USB 1, the second as USB 2 and my second 2TB drive as USB 3. I haven't tried it, but I'm confident a second partioned drive would show up as USB 3 & 4.
Alternately, my Seagate GoFLex TV combines all three "drives" into one single list.
Edit: As for your USB "splitter", I'm sure you're referring to a USB hub. Those aren't recoginzed by the WDTV Live Plus. I believe the WDTV Live Hub does support a USB Hub or alternately, there's the B-Rad firmware which supports some USB hubs on the WDTV Live Plus.Last edited by lingyi; 2nd Jun 2012 at 00:47.
NO jaay4 dont go to all that trouble .. far easier and Free .. just flash one of your wdtv (preferably networked one as that will be the later, faster model) with b-rad.cc firmware, then you can use use USB hubs to your hearts content. Just google brad.cc and read the forums .. works well, and it has added bonus youtubeHD on your Wdtv. as previously mentioned by moontrash
Why not put all your drives in a MediaSonic 4 Bay USB 2.0 case? http://www.amazon.com/ProBox-Drive-Enclosure-3-5-inch-drive/dp/B002UUPWP6/ref=sr_1_2?s...0060383&sr=1-2
I thought about this, but I build a WHS 2011 with 4TB... ($300)
Why avoid a network? I stream from the server wireless (802.11n) all the time???? In HD too (reduced bit rate, so what...)Project Digital: Eliminate All Physical Media is finally underway!
USB media player
By pinetop in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Dec 2011, 18:56 -
DV-AVI playback via Blu-Ray player or WDTV with USB connected HDD
By Splodger in forum Newbie / General discussionsReplies: 14Last Post: 27th Jun 2011, 21:12 -
how to get over 3TB limit in win XP 32bit (connected over usb)
By deejay.2001 in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 21:59 -
How arrange folders when external storage connected to the USB of DVP
By barbazuk in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jul 2009, 01:47 -
Usb Ext drive not recognized when laptop connected to mains charger??????
By Humbug in forum ComputerReplies: 1Last Post: 19th Feb 2009, 10:46
