I have been using TMPGenc to convert asf and non-compliant mpeg files to VCD. I have several files that ran fine for a while (2%) and then slowed down almost to a halt. I checked the CPU usage and it showed the CPU was not very active (spikes of 30% to 50% every once in a while) but TMPGne is still working. When TMPGenc is working smoothly, the CPU usage is 100%. What is slowing it down? Any ideas??
Is there anything wrong with the files or TMPGenc (I believe mine is the latest version) or a combination of both? I have also tried to demux and remux and use ASFTool and other tools to repair the files with no improvement. What is wrong here? Should I cut the file into pieces and encode separately and then merge them? Please advise. Thanks.
Results 1 to 1 of 1
TMPGEnc for HD to SD conversion?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 14th Oct 2011, 16:37 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:39 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
