So I'm trying to change the framerate on a video from 29.97 fps to 59.94 with avidemux, I've been trying to get the audio in sync, but it has failed to do so. I know there may not be a way to do this, but if there is a way, let me know. I know this is impossible to do, but I need some help here. Once again, if there is one way let me know. I doubt there is a way.
What I'm exactly trying to do is increase the framerate of some of my videos because I am making a movie with the fps as 59.94 fps, and trying to keep it in sync. Do you have any step by step instructions?
But WHY are you doing this ?
You need to insert frames by one of those 3 methods. I don't think Avidemux can do this
You can do this in editors such NLE's such as vegas, premiere , fcp , Or avisynth (but it's a bit of a learning curve).
There are side effects to each method (you can't get more real FPS for nothing - so it won't be "real" 59.94 content, even though the FPS is 59.94.) -
To illustrate: lets just use 30fps and 60fps for this example .
You start with a 120 frame, 30fps clip . So that is 4 seconds duration because 120 frames / 30fps = 4 seconds
Changing the FPS to 60, will make it 2 seconds because 120 frames / 60 fps = 2 seconds . This is just simple math . So audio is out of sync, or you have "chipmunk" voices as it's sped up
If you double BOTH the FPS and the #frames , then 240 frames / 60 fps = 4 seconds and everything is in sync as the original . Thus you have to double the number of frames if you double the FPS
BUT - where do you get those EXTRA frames from?
1) If you just use duplicates, it will look exactly as the original in terms of motion
2) If you use blends, it will be blurry but the motion will be the same as original
3) If you use motion interpolation - it will be smoother than the original (it will approach the look of "real" 59.94 footage), but there can be weird edge morphing artifacts. It can work ok on some types of footage by fail miserably on others
Best framerate conversion? (eg: 23.97 to 30 fps to avoid judder)
By ionone in forum Video ConversionReplies: 16Last Post: 12th Mar 2014, 08:56 -
Changing fps
By jh443 in forum Video ConversionReplies: 13Last Post: 29th Oct 2008, 21:57 -
Framerate Changing to 30.1328?
By tacman1123 in forum EditingReplies: 0Last Post: 22nd May 2008, 15:22 -
Changing the framerate during conversion
By 2nickelstripper in forum Video ConversionReplies: 2Last Post: 7th Dec 2007, 08:46 -
Framerate FAQ:60 fps vs 30 fps
By Breakpack in forum Capturing and VCRReplies: 1Last Post: 9th Jun 2007, 05:42
