While setting up a video for conversion I received this message "ffmpeg stopped working" and an error code 53.
How can I correct this. The video is in an mp4 format.
Here is the log that was created:
<5/29/2012 1:28:14 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 3
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: 1-Will It Snow at Christmas Ep 1-3
DVD Menu: Motion Menu
Output Folder: F:\K Drama\Will It Snow at Christmas\Will It Snow at Christmas-DVD
Delete Temp Process Files: Yes
Delete Working Files: No
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Arial 18pt (255,255,0)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: MATSHITA DVD-RAM UJ862ES 1.90
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 1
TITLE 1 SOURCE FILES
Video: F:\K Drama\Will It Snow at Christmas\Will It Snow - 01.mp4
Info: AVC - 400 kbps - 624x352 - DAR 1.773 - 29.97 fps (CFR) - Progressive - 1:05:21 hours - 117525 frames
Audio 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 01.mp4
Info: AAC LC-SBR - 39 kbps - VBR - 2 ch - 48000 / 24000 Hz - 1:05:21 hours (0 ms delay) - Internal
Subs 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 01.srt
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 01.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 01.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,480,0,0,0,-0)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1290.5 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\1-Will It Snow at Christmas Ep 1-3_0_Title_01_Will It Snow - 01.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\1-Will It Snow at Christmas Ep 1-3_0_Title_01_Will It Snow - 01_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\1-Will It Snow at Christmas Ep 1-3_0_Title_01_Will It Snow - 01.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\1-Will It Snow at Christmas Ep 1-3_0_Title_01_Will It Snow - 01.HCenc.log
*MAXBITRATE 9000
*BITRATE 2761
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<5/29/2012 1:28:33 PM>
CHECK LOG FILE <F:\K DRAMA\WILL IT SNOW AT CHRISTMAS\WILL IT SNOW AT CHRISTMAS-DVD\1-WILL IT SNOW AT CHRISTMAS EP 1-3_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.4.2
many thankss
Are you sure that the error message reports ffmpeg and not HCenc?
Some common troubleshooting:
1. Have you installed Haali Media Splitter for mp4/mkv splitting?
2. Have you installed a good directshow codecs suite (like ffdshow)?
3. Any errors messages when you use the 'Preview Title Output' function?
Bye -
Thanks for the reply, The error message does say FFmpeg has stopped working. Also an error 53 appears as well.
I did reinstall the FFDshow and so far haven't received the message (crossing fingers) Will let you know.
Do I need to install the Haali Media Splitter and what is it for?
thanks again -
Haali Media Splitter is a good mp4/mkv containers splitter. It is used to separate the audio/video/subs streams and let the decoders access them directly. You may use other splitters but I usually suggest Haali's. It comes with AVStoDVD installer package.
Bye -
Thanks again for the reply.
I just started the conversion and it seems to be working.
I did reinstall AVStoDVD but I didn't reinstall the FFDShow. And I should have the Haali media Splitter somewhere in the AVStoDVD package.
So I am hoping all goes well from here.
Again many thanks
AVStoDVD stops working after encoding video
By tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 07:10 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 09:00 -
AVStoDVD 2.2.5 not working
By ghosthunter38 in forum Authoring (DVD)Replies: 1Last Post: 1st Jan 2010, 16:20 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
