  1. I've been using VirtualDub to cut avi files for gifs for a while now and suddenly, yesterday I got these errors while trying to skip through the file
    "An out-of-bounds memory access (access violation) occurred in module 'xvid'..."
    "An integer division by zero occurred in module 'xvid'..."
    crash report
    VirtualDub crash report -- build 32842 (release)
    Disassembly:
    10007660: d1e2 shl edx, 1
    10007662: 8b442418 mov eax, [esp+18h]
    10007666: 08c0 or al, al
    10007668: 0f8573000000 jnz 100076e1
    1000766e: 0f6f06 movq mm0, [esi]
    10007671: 0f6f0c0e movq mm1, [esi+ecx]
    10007675: 0f0f4601bf pavgusb mm0, [esi+01h]
    1000767a: 0f0f4c0e01bf pavgusb mm1, [esi+ecx+01h]
    10007680: 0f7f07 movq [edi], mm0
    10007683: 0f7f0c0f movq [edi+ecx], mm1
    10007687: 01d6 add esi, edx
    10007689: 01d7 add edi, edx
    1000768b: 0f6f06 movq mm0, [esi]
    1000768e: 0f6f0c0e movq mm1, [esi+ecx]
    10007692: 0f0f4601bf pavgusb mm0, [esi+01h]
    10007697: 0f0f4c0e01bf pavgusb mm1, [esi+ecx+01h]
    1000769d: 0f7f07 movq [edi], mm0
    100076a0: 0f7f0c0f movq [edi+ecx], mm1
    100076a4: 01d6 add esi, edx
    100076a6: 01d7 add edi, edx
    100076a8: 0f6f06 movq mm0, [esi]
    100076ab: 0f6f0c0e movq mm1, [esi+ecx]
    100076af: 0f0f4601bf pavgusb mm0, [esi+01h]
    100076b4: 0f0f4c0e01bf pavgusb mm1, [esi+ecx+01h]
    100076ba: 0f7f07 movq [edi], mm0
    100076bd: 0f7f0c0f movq [edi+ecx], mm1
    100076c1: 01d6 add esi, edx
    100076c3: 01d7 add edi, edx
    100076c5: 0f6f06 movq mm0, [esi]
    100076c8: 0f6f0c0e movq mm1, [esi+ecx]
    100076cc: 0f0f4601bf pavgusb mm0, [esi+01h]
    100076d1: 0f0f4c0e01bf pavgusb mm1, [esi+ecx+01h]
    100076d7: 0f7f07 movq [edi], mm0
    100076da: 0f7f0c0f movq [edi+ecx], mm1
    100076de: 5f pop edi
    100076df: 5e pop esi
    100076e0: c3 ret
    100076e1: 0f6f3d68ff0310 movq mm7, [1003ff68]
    100076e8: b804000000 mov eax, 00000004
    100076ed: 0f6f06 movq mm0, [esi] <-- FAULT
    100076f0: 0f6f0c0e movq mm1, [esi+ecx]
    100076f4: 0f6f5601 movq mm2, [esi+01h]
    100076f8: 0f6f5c0e01 movq mm3, [esi+ecx+01h]
    100076fd: 0f6fe0 movq mm4, mm0
    10007700: 0f6fe9 movq mm5, mm1
    10007703: 0f0fc2bf pavgusb mm0, mm2
    10007707: 0f0fcbbf pavgusb mm1, mm3
    1000770b: 0ffcd4 paddb mm2, mm4
    1000770e: 0ffcdd paddb mm3, mm5
    10007711: 0fdbd7 pand mm2, mm7
    10007714: 0fdbdf pand mm3, mm7
    10007717: 0fd8c2 psubusb mm0, mm2
    1000771a: 0fd8cb psubusb mm1, mm3
    1000771d: 0f7f07 movq [edi], mm0
    10007720: 0f7f0c0f movq [edi+ecx], mm1
    10007724: 01d6 add esi, edx
    10007726: 01d7 add edi, edx
    10007728: 48 dec eax
    10007729: 75c2 jnz 100076ed
    1000772b: 5f pop edi
    1000772c: 5e pop esi
    1000772d: c3 ret
    1000772e: 90 nop
    1000772f: 90 nop
    10007730: 56 push esi
    10007731: 57 push edi
    10007732: 8b442418 mov eax, [esp+18h]
    10007736: 0f6f3cc548ff03 movq mm7, [eax*8+1003ff48]
    10
    1000773e: 8b7c240c mov edi, [esp+0ch]
    10007742: 8b742410 mov esi, [esp+10h]
    10007746: 8b542414 mov edx, [esp+14h]
    1000774a: b808000000 mov eax, 00000008
    1000774f: 0feff6 pxor mm6, mm6
    10007752: 0f6f06 movq mm0, [esi]
    10007755: 0f6f5601 movq mm2, [esi+01h]
    10007759: 0f6fc8 movq mm1, mm0
    1000775c: 0f6fda movq mm3, mm2
    1000775f: 0f db 0fh
    Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
    Windows 6.1 (Windows Vista x64 build 7601) [Service Pack 1]
    EAX = 00000004
    EBX = 00000000
    ECX = 00000540
    EDX = 00000a80
    EBP = 000002a0
    ESI = 4575a84f
    EDI = 0537a850
    ESP = 0018ec88
    EIP = 100076ed
    EFLAGS = 00210202
    FPUCW = 027f
    FPUTW = aaaa
    Crash reason: Access Violation
    Crash context:
    ...reading address 4575A84F...
    ...while decompressing video frame 2362 (VideoSource.cpp:2141)...
    ...while using input buffer at 04f91e30-04f92b64 (VideoSource.cpp:2140)...
    ...while using output buffer at 04fe0080-05364083 (VideoSource.cpp:2139).
    Pointer dumps:
    EDI 0537a850: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    ESP 0018ec88: 00000000 00000540 10013c47 0537a850 4575a84f 00000540 00000001 0018f3b4
    0018eca8: 071c0030 00000000 04361a00 00000320 0575a850 7fffffff 3fffffff 00000000
    0018ecc8: 00000000 00002a00 00000001 0018f010 0537a850 043e4fc0 054e2a60 0018ecf0
    0018ece8: 0000002c 0018eda0 00000000 00010001 0000ffff 00000000 0000ffff 0000ffff
    Thread call stack:
    100076ed: xvid!xvid_encore [10000000+7520+1cd]
    10013c47: xvid!xvid_encore [10000000+7520+c727]
    10012840: xvid!xvid_encore [10000000+7520+b320]
    10014897: xvid!xvid_encore [10000000+7520+d377]
    10014fa4: xvid!xvid_encore [10000000+7520+da84]
    100180e3: xvid!xvid_encore [10000000+7520+10bc3]
    1000750e: xvid!xvid_decore [10000000+74d0+3e]
    10003ba4: xvid!00003ba4
    10006e3c: xvid!DriverProc [10000000+6b90+2ac]
    005b34b0: (special)()
    004c32ac: AVIReadCache::WriteBegin()
    005bc1b5: _VEC_memcpy()
    005bc217: _VEC_memcpy()
    004c2da9: AVIReadCache::Write()
    74911759: MSVFW32!ICSendMessage [74910000+1728+31]
    74914e27: MSVFW32!ICDecompress [74910000+4dea+3d]
    0059d1b1: VDVideoDecompressorVCM:ecompressFrame()
    004dd333: VideoSourceAVI:treamGetFrame()
    0043360a: VDFilterFrameVideoSource::RunRequests()
    757d62fa: USER32!gapfnScSendMessage [757c0000+15fc8+332]
    005b2fb6: malloc()
    004619f6: VDProject::UpdateFrame()
    00432855: VDFilterFrameRequest::CreateClient()
    0043289d: VDFilterFrameRequest::CreateClient()
    00431bb2: VDFilterFrameManualSource::CreateRequest()
    0043c92b: FilterSystem::RequestFrame()
    00462752: VDProject:isplayFrame()
    76f9f8ca: ntdll!NtCallbackReturn [76f80000+1f8b8+12]
    00460b28: VDProject::MoveToFrame()
    004672f3: VDProjectUI::OnPositionNotify()
    0046d85a: VDProjectUI::MainWndProc()
    00465ac0: VDProjectUI::WndProc()
    00479b65: VDUIFrame::StaticWndProc()
    757d6d3a: USER32!GetThreadDesktop [757c0000+16c63+d7]
    757d6ce9: USER32!GetThreadDesktop [757c0000+16c63+86]
    757d965e: USER32!GetWindow [757c0000+1926e+3f0]
    757e617a: USER32!SendMessageA [757c0000+2612e+4c]
    004b21db: VDPositionControlW32::Notify()
    004b2f5c: VDPositionControlW32::WndProc()
    004b2e8f: VDPositionControlW32::WndProc()
    004b32a2: VDPositionControlW32::StaticWndProc()
    76f9010a: ntdll!KiUserCallbackDispatcher [76f80000+100dc+2e]
    757d77c4: USER32!CharPrevW [757c0000+1768c+138]
    757e60dc: USER32!PeekMessageA [757c0000+25f74+168]
    757d7bca: USER32!DispatchMessageA [757c0000+17bbb+f]
    00452596: WinMain@16()
    005b78db: __tmainCRTStartup()
    74f4339a: kernel32!BaseThreadInitThunk [74f30000+13388+12]
    76fb9ef2: ntdll!RtlInitializeExceptionChain [76f80000+39e8f+63]
    76fb9ec5: ntdll!RtlInitializeExceptionChain [76f80000+39e8f+36]
    -- End of report
    I have tried reinstalling divx codecs and reinstalling virtualdub but it hasn't worked.
  2. You have a corrupt file. Xvid is having trouble decoding it. Try disabling Xvid, and setting Divx to decode all related fourccs. Maybe Divx will handle the corrupt file better.
