I have philips BDP7500Sl and it splitted a mkv file so that i can copy it to my usb .I splitted the file using mktoolnix and copied it to my usb then when i play the splitted mkv file it only shows 100% on my player nothing else.
plsssss help
Closed Thread
Try disable header compression in mkvtoolnix, under file->options and disable header removal compression. Restart mkvmergegui. And then split.
If the srt is separate to the MKV (which I assume it is).....
Open the original MKV with mkvtoolnix and add the srt file to it. Resave it as a new MKV while splitting it as required. If you want to keep the subtitles as seperate files open the split MKV sections with MKVCleaver (make sure MKVCleaver is version 0.5.0.4, otherwise Google and download the update patch). Extract the subtitle stream from each part. You'll now have an appropriate srt file for each one.
If you want to, you can re-open each part of the split MKV using mkvtoolnix, de-select the subtitle track and re-save each one as a new MKV without the subtitles included, keeping the subtitles as separate files only.
I have a new mkv which is not splitting
the error is
mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv': Using the demultiplexer for the format 'Matroska'.
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv' track 0: Using the output module for the format 'AVC/h.264'.
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv' track 1: Using the output module for the format 'DTS'.
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv' track 2: Using the output module for the format 'text subtitles'.
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv' track 3: Using the output module for the format 'text subtitles'.
'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv' track 4: Using the output module for the format 'text subtitles'.
The file 'C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.V engeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks (1)-001.mkv' has been opened for writing.
C:\Users\Sanjay\Downloads\Ghost.Rider.Spirit.Of.Ve ngeance.2011.720p.BluRay.X264-SPARKS [PublicHD]\ghost.rider.spirit.of.vengeance.2011.720p.bluray. x264-sparks.mkv: Error in the Matroska file structure at position 4340606. Resyncing to the next level 1 element.
Still resyncing at position 17606267.
Still resyncing at position 33524606.
Still resyncing at position 49542476.
Still resyncing at position 61839338.
Still resyncing at position 74530687.
Still resyncing at position 87037678.
Still resyncing at position 99282591.
Still resyncing at position 109400882.
Still resyncing at position 118885916.
Still resyncing at position 127418520.
Still resyncing at position 138474849.
Still resyncing at position 150819739.
Still resyncing at position 162194887.
Still resyncing at position 174508301.
Still resyncing at position 184415138.
Still resyncing at position 193641410.
and so onnnn............................................. ...........................
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
1080p Mkv To DVD-DL 8.5 Gig To Play On PS3 and Blu Ray
By Chevy434 in forum Authoring (Blu-ray)Replies: 5Last Post: 20th May 2010, 05:04 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 15:58
plsssss help
