i tried using tsmuxer....but its also not adding the file...error is cant detect the stream type...changed the extenstion then tried adding with no result
Results 31 to 33 of 33
please provide some more tricks and tips...i can play the file only in the setop boxes of the same type provided by my cable operator .
If cable DVR recordings are truly encrypted, you will need more than just simple tricks to make the recordings portable. Only decrypting such recordings allows you to play them on something other than the box that made them. ...but almost nobody succeeds in breaking actual encryption.
Your best chance at saving a copy is to buy a capture device and using it to re-record anything that you want to keep as the DVR plays it. If you need to record via HDMI, then you will also need an HDMI splitter that removes HDCP as a side effect.
Avanti -FFmpeg Conversion to Transport stream
By manding74 in forum Video ConversionReplies: 20Last Post: 6th Jul 2011, 09:44 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
Hexadecimal header and offset of a MPEG-2 Transport stream file?
By coconut83 in forum ComputerReplies: 1Last Post: 26th Oct 2010, 11:41 -
Panasonic HD Video Camera - .MTS file vs. MPEG-2 transport stream
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 10th Aug 2010, 23:04 -
Conversion from Transport Stream
By mparter in forum Video ConversionReplies: 3Last Post: 7th Mar 2008, 15:02
