Speedfan shows CPU useage and during BR encoding my useage is over 90% on all 8 cores on my I7 running XP But on my AMD 1090T it's only about 50% on four cores with almost no useage on the other two cores running W7.
Results 1 to 12 of 12
Is that for VC-1 as well? I've found that doesn't multi-thread as well as H264. For VC-1, I get about 50%, for H264, 98% or so on my 1090T. All cores about equally active either way.
Pull! Bang! Darn! -
So you are running an 8 core I7 with 6Gb of ram and only running XP
I7 920 is 4 core with 8 threads.What program are you using to encode?
Monitor using HWINFO:
http://www.hwinfo.com/download64.html
If you get the same results then BDRB must be optimized for Intel. -
Nope, I have a six-core Phenom II 1090T and as I said before, X264 encoder runs in the high nineties, all cores. With BDRB as the front end or anything else that uses X264. Except when re-encoding VC-1. (Decoder bottleneck?)
If you go to Tom's Hardware and look up some of the year-old benchmark articles for the Phenom II six-cores, specifically the results for video encoding, you'll find no hint of anything like what you describe. X264 encoding was one of the few areas where the Phenom II x6 CPUs could top the comparable Intel CPUs, at that time anyway.
I wonder if you shouldn't clear your CMOS and go into your BIOS and make sure you re-enable all six cores.Pull! Bang! Darn! -
I installed XP on my 1090T and it now has 100% cpu useage. It would appear my problem was caused by windows 7. I had installed W7 a few weeks ago as an upgrade from XP from the desktop.
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
inkjet ink useage
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2009, 08:18 -
CPU NOT Multiprocessing or what?
By Jo The Veteran in forum ComputerReplies: 23Last Post: 22nd Dec 2008, 12:43 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
