Hi,
I am having trouble getting an avi video into AVIDemux.
When i open the file in avidemux it opens some wacky distrorted video with all of these crazy colors. I can see the main shapes in the background, but just barely and they are not in correct placement.
The avi file may be uncompressed. It is an avi that i exported from a 3dCAD animation. (Inventor 2010)
Any help would be great.
Thank you
Results 1 to 9 of 9
Hi,
Is there anyway i can get the info in windows somewhere. Its a company computer, and they have to approve all software that we download, which can take a while.
Thanks -
OK, So i'm not sure where/what info you need, but here is what mediainfo was reading.
AVI
RGB
32bpp raw RGB
basic windows bitmap format
If that isn't the info, could you very briefly describe how to get it was media info?
Thanks -
It's uncompressed 8bit RGB, but has alpha channel (might be dummy alpha)
avidemux should be able to open it, did you try most recent versions?
http://avidemux.razorbyte.com.au/
if not, vdub should be able to open it
(I know , you have to bug IT dept. again)
Exactly what are you trying to do in avidemux? -
It seems to work now, I had to export it from inventor as a different codec or something (Compressed instead of uncompressed) Seems to work fine now. Thanks for your help!
Dario
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Avidemux issue...
By Sedoc94 in forum Newbie / General discussionsReplies: 12Last Post: 31st May 2010, 09:57 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
Sound delay issue after MPEG2 editing (avidemux)
By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 05:55 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 10:27
