Hello,
I 'm trying to capture video from my camcoder via FireWire connection.
I noticed that any capturing program saves result as an AVI file.
But the problem is that my 30 seconds movie takes about 80Mb avi and 8 minutes 3.5Gb. I want to capture all 60 minutes but figured out I will not have enough space on my hard drive.
* Is it supposed to be like it?
* Anybody knows how to make the result avi smaller without loosing quality?
I captured with recommended frame size 320x240, 30fm/s NTSC.
After I burned a VCD with a sample 30 secs movie I noticed that quality was terrible - looks like 320x240 resolution is too small.
I found that my TV uses a mask of about 520 vertical lines.
* Any advice on what is the best resolution to choose?
Thank you,
Eugene
same problem here. cant figure out how to convert to divx....virtualdub is not working for reason...wont even opn the captured avi file
Yes...all your AVI files wil be large, the standard VirtuadBud AVI for say 60 min will be about 35-40 GB, however if you use a DV Avi format it will be about 10-15 GB, I use Premiere 6.0 to capture from firewire in the DV AVi format. After you convert to MPEG it be a very small file to burn to VCD or SVCD.
Bud -
That why dvcam did not take off,
and sony, sharp.. and other are trying out mpeg2 .. mpeg4...mov -
Sorry SingSing, but i disagree. I think the mini DV format Has already "taken off", and with new computers having much bigger drives the space limitation won't be that much of a problem.
8)
Correct size Resolution for AVI
By Sliztzan in forum EditingReplies: 45Last Post: 25th May 2010, 11:01 -
How much does resolution affect file size?
By milkydoo in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 18:29 -
MeGUI: Problem calculating AVI file size
By fakecake in forum Newbie / General discussionsReplies: 9Last Post: 1st Feb 2009, 09:11 -
AVI File Size problem
By prcole18 in forum Capturing and VCRReplies: 5Last Post: 14th Jul 2008, 19:05 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
