Hi,
I am using latest tmpgenc and tried to convert avi to vcd/pal
It worked several times before until I got this message:
Illegal floating decimal point calculation order
this messages shows up on different times. e.g. after 5% progress
or 53% progress. It is not the same position.
any ideas?
Try looking on the web page for a certain plugin for AVI's . http://www.tmpgenc.net/
I'm having the same problem with a AVI I downloaded from the newsgroup. The AVI file I have is corrupted in one section which cause TMPGEnc to crash. Try playing your AVI at the spot where the program crashes.
Try playing the file in Virtualdub and see if you get an error message anywhere. If you do, then it's probably a freeze frame at that spot. Look for a program called DivX antifreeze (not the player plugin, the program) which will fix these freeze frames.
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
