I am using a program called 321Studio for copying the DVD's. I have had pretty good luck but on some of them I get a fault, after hours of encoding, I get a fault saying " MPG2Dec:Too much sample-try other frame rate or change detect/force 24hz' floe"
Now I have done this and get the same results. I have copied at least a dozen with the setup they told me to use and they were perfect but I have had 4 that I have given up on and deleted. What the heck is going on?
What exactly is this fault telling me. Are there some DVD's that defy encoding?
I am an old man but not stupid.A little help would be appreciated--Royal
Life is for the living- do it!! :0)
hmm.. that 321studio wouldn't happen to be something you bought have you? cause it sure sounds like old version of DVDx to me! I would strongly suggest you check the guides here, and just to be on the safe side, get the latest DVDx and compare it to your program.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 13:09
