Results 1 to 9 of 9
  1. After reformatting my computer I can't get AVSPmod to work, it gives me an error log:
    [Tue May 22 08:26:18 2012]
    File "run.py", line 6, in <module>
    File "AvsP.pyo", line 13863, in main
    File "wx\_core.pyo", line 7981, in __init__
    File "wx\_core.pyo", line 7555, in _BootstrapApp
    File "AvsP.pyo", line 13853, in OnInit
    File "AvsP.pyo", line 4165, in __init__
    File "AvsP.pyo", line 4784, in defineFilterInfo
    File "AvsP.pyo", line 5012, in getFilterInfoFromAvisynth
    WindowsError: exception: access violation reading 0x00000000
    Which avisynth version have you installed?
    Your OS?
  3. Ok my bad, I had avisynth 2.6 beta installed, it seems AVSPmod requires avisynth 2.58 stable. Thanks Baldrick.
    Great
  5. I use it with 2.6 alpha MT set build. Just sayin'.
    Jul 2009
    Spain
    Not true.
    I suspect you had something wrong with your Avisynth installation, eg incompatible or corrupt plugin in the plugins folder.
  7. OK thanks. Is there something corrupt with the avisynth 2.6alpha3 download on sourceforge? It just ain't working for me here!?
  8. Meh I figure it is something to do with the MCTemporalDenoise self-installer. I think I will manually install all the filters myself. Man, I hate avisynth sometimes...
    I just had this happen, too.
    AvsPmod was throwing a fit because "ffavisynth.avsi" was in the plugins folder.
