Can someone help me? i want to put a few quicktime vids on a dvd but i dont know how.
you want to just copy the files to a dvd or create a dvd playable in a standalone?
Just make sure these aren't store bought files. If they are then they can't be converted directly. You'd have to either use requiem to strip the protection (assuming you bought these files yourself - otherwise you're not supposed to be doing this if they aren't ones you bought) or do a screen capture with something like tunebite or another screen capture program).
If these are unprotected files than you can easily convert to regular dvd mode with avstodvd as usually_quiet suggested.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 17:24 -
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
Youtube HD mp4 file can't save as mov by quicktime
By yozloy in forum Video ConversionReplies: 3Last Post: 8th Jan 2010, 03:05 -
can't save as quicktime file? why not?
By kevs in forum MacReplies: 8Last Post: 5th Jun 2007, 13:46
