Hello!
I prepared a DVD of a recital with audio and video from different sources. I took the video myself and used the audio from the house recording engineer. The audio quality is important because the DVD will be used for auditions. I rendered the video and audio separately: MPG2 and WAV (PCM 16bit 48MHz). The prepared DVD plays perfectly from my hard drive with VLC. There are loud pops when playing the burned disc, however, and a few seconds was cut off the end of one track. I assume the problem is with the burning process. I have an old Plextor 16x usb burner and I'm using Sony DVD-R media, which I think is recommended for my drive. Can someone please help me?
Thanks,
D
try again using imgburn to create the dvd. make sure the verify option is checked. if the pops are still there and in the same places the problem is in the encoding. if there but in different places, try to find some quality verbatim or taiyo yuden discs.
Is there something better than DVD Architect 5 to use with Vegas Pro?
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 12th Dec 2010, 20:46 -
DVD Architect Pro v5.0b Help - Gaps Between Chapters
By shawncumby in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2010, 00:23 -
DVD Architect Pro 5.0 Help - Introduction Media Help
By shawncumby in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2010, 16:34 -
Sony DVD Architect Pro 5.0b No Audio Stream
By petersm2 in forum Authoring (DVD)Replies: 8Last Post: 4th Jun 2009, 21:20 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 16:51
