I,ve been using virtualdub and tmpgenc to cut and convert movies for a few months now and in the beginning everything was oke but then we had a problem with our computer and we had to format it. After we did that every time i open a movie in virtualdub it gives the message "virtualdub has detected an improper audio encoding in the source avi file......etc. and when i convert the movie the audio is really out of sync (+- 3sec.). I think it might has to do something with the divx codec but i don't know for sure. I've tried a few things but i'm kind of a rookie when it comes to computers so if anyone could help me that would be great!!!
thanks, yoost
I have the same problem all the time.
In my case it usually helps, if i convert sound from avi to wav with virualdub and then select saved wav file as audio file when converting with TMPGEnc. See guide under "convert" section.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Audio problem
By Goten in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 22:44 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 07:48
