Hi There, sorry I'm a bit of a noob, but I've used make MKV and I love the fact it creates a very fast rip of a DVD, in about 10-12 minutes. I know its a large file because nothing is compressed/recoded, but I don't mind the large file. I think the videa is the same MPEG 2 video, in an mkv container.
My DVD player has USB support but only for avi, not mkv. I find ripping a dvd to an avi with XVID/DivX etc takes too long, but every program I've tried always wants to reencode the audio and video streams. Is there a program which works like makeMKV, and just dumps the same audio and video into an avi container without recoding it? I've looked at using programs to extarct the video/audio from the finsihed mkv, and then place that back into another container, but it seems quite time consuming, and the the mai thing I want is just an avi that rips veyr quickly.
Thanks for any help you can give me
Nope. Your dvd player only supports avi with divx/xvid so you must reconvert.
Hi, Thanks for the quick reply. I tried simply renaming the file and trying it and when I renamed it .mpeg, the video came out on the player, although a little choppy, and withotu sound. I think my player supports the video format within the mkv container.
Is it possible to rip the DVD to a single MPEG 2 instead? Would this be quite quick? Thanks -
Xmedia Recode will convert a mpeg 2 MKV to an MP4 just a few minutes if you check the video copy box.
This enables me to play the video on my DVD player that does not have mkv support.
Tony
DVD ripping and conversion problem
By Tapash in forum DVD RippingReplies: 6Last Post: 17th May 2012, 08:06 -
Ripping with MakeMKV and some questions
By Choque in forum Blu-ray RippingReplies: 1Last Post: 11th May 2011, 12:44 -
MakeMKV DVD issue
By trooper11 in forum DVD RippingReplies: 6Last Post: 7th Oct 2010, 23:47 -
ripping Blu-ray using MakeMKV question
By andy99 in forum Blu-ray RippingReplies: 2Last Post: 7th Jul 2010, 11:23 -
MakeMKV
By magmo in forum DVD RippingReplies: 1Last Post: 10th Nov 2009, 13:59
