Hi there,
Is it even possible to use this script (after modification) to get the size/quality ration like the ripped dvd movies? For example I have a dvdrip of Mission Impossible 3, length - 2:12:56 resolution - 1280x536, size - 771 MB. So in average it's about 5.8 MB/min. I've tried to convert my HD video from LUMIX camera into something similar but couldn't find the right combination of parameters.
So the question is - is it possible in principle? If it's only to change a few parameters in ffmpeg command line could someone explain it to me? I'd be much appreciate it
wondering who encodes dvd input material at a higher resolution,... (720x480 or 720x576 -> 1280x536 seems like a waste of bit rate)I have a dvdrip of Mission Impossible 3, length - 2:12:56 resolution - 1280x536, size
5.8 MB/min ~ 773kBit/s seems too low for any decent quality at a resolution of 1280x536
-> you might want to check you facts, this just seems wrong on too many levels to take it seriously -
The video from your Lumix camera is probably too noisy and shaky (and probably too high a frame rate too) to compress as well as a DVD rip. What's the problem you're having? Bad picture quality? Or failure to work at all?
3ivx Batch Conversion Available? Possible Script?
By fitch.j in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2009, 05:24 -
Need conversion script for my website
By mdhuma in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2009, 01:16 -
Video Conversion Script
By paug in forum Video Streaming DownloadingReplies: 1Last Post: 16th Oct 2008, 02:49 -
Avisynth script problem (aac to wav conversion)
By greggery in forum Video ConversionReplies: 0Last Post: 22nd Nov 2007, 11:59 -
What is the best script for my DVD conversion.
By sneaux in forum Authoring (DVD)Replies: 2Last Post: 19th Jul 2007, 04:43
