Are there any good programs that will let me copy my games to my computer?
I tried Alcohol 120%, but it could not work with my Scrabble game.
The disc was mounted on a virtual drive and started to play and then said "wrong disc inserted."
I don't mind paying for a program as long as it can copy correctly.
Paul
Game discs are essentially "data" discs, making it much easier for companies to add "very difficult to overcome" copy protection to them. There are even special tools that you may need to run in order to identify the type of protection used on the disc, then go and find the proper tool/procedure to copy it.
Most of the time it's not worth the hassle. -
Check out www.gamecopyworld.com for a solution to game discs ... game index from mirror 3, click S and look for version.
Ditto. Gamecopyworld will be able to give you what you need if an answer is to be found. Most often its as easy as installing the game and replace the game launcher with a fixed launcher that does not do the validation checks so you don't have to have the disk in the drive to play the game. But as far as making a playable backup I wouldn't even try most times its not worth the effort.
Murphy's law taught me everything I know. -
Thanks to all who replied.
I thought it would be a simple process.
Now I know it is not worth the hassle. -
Depends ... games after 2007 are difficult but not impossible but having the correct dvd burner is what makes the process easier.
Clonecd image, patched using bwa, burn at 2x ... once securom and safedisc hit v4.6 it was made more difficult which is where them nocd exe's come into play.
Backing up XBOX games
By HARRYSPADGE in forum ComputerReplies: 22Last Post: 16th Feb 2013, 19:27 -
Backing up of Wii games?
By freebird73717 in forum Off topicReplies: 6Last Post: 6th Dec 2011, 11:10 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12 -
Backing up Games?
By LCE in forum Off topicReplies: 2Last Post: 23rd Oct 2007, 23:45 -
Backing up EA Sports Games
By drew23977 in forum Off topicReplies: 3Last Post: 19th Jul 2007, 01:09
