Results 1 to 17 of 17
  1. Ok soa while ago i accidently deleted some Cell Phone vids from my pc,they were 3gpp2 files. Anyway i recently recovered some of them using some recover program. Problem is whenever i try to play i cant. it says error code 2048 quicktime cannot recognize file or some thing. So i tried to play in VLC player still wont work. the file is there because it says 3mb 19mb ect. Please help me as these vids are very important to me
    Try video repair tool. Try first the free trial, it will try repair half the movie.
  3. thanks but that didnt work,even the preview was scrambles and it was like a mix of other vids from what i could see
    That doesn't sound good. The video has probably been overwritten by other video data.
  5. and how would i fix that?
  6. Member classfour's Avatar
    The Heartland, United States
    Have you tried recuva to recover the file? You might have better results???
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  7. Originally Posted by anthony247 View Post
    You don't. The only way is to go back to the hard drive and use better recovery software.
  8. Member zoobie's Avatar
    Feb 2005
    Florida
    ...like the free MiniTool Power Data Recovery
  9. Member Cornucopia's Avatar
    Or, if they've been overwritten, you are totally, irreversably SOL.
  10. thank u guys recuva totally worked! i am so happy. now how do i put quicktime mov on dvd?
  11. DECEASED
    Jun 2009
    Heaven
    We're glad you have managed to solve your problem
    But now, please,
    1) add a [SOLVED] tag to the title of this thread
    2) open a brand-new thread for your brand-new question
    Cheers.
  12. how do i add tag?
  13. Member zoobie's Avatar
    Feb 2005
    Florida
    edit your first post's title
  14. DECEASED
    Jun 2009
    Heaven
    ^ Go to the first post, click on "Edit", then change the title, i.e. ,
    replace "Please Help Me Save My Files" with
    "[SOLVED] Please Help Me Save My Files"
    Oct 2010
    England
    I couldn't see any way to modify the title of threads I created. OP has probably got the same problem.
    Anyone know the solution?
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Click edit and GO ADVANCED.
    Oct 2010
    England
    How did I miss that...
    Thanks Baldrick.
