Forgive me, I'm not an expert on these things, and I've been reading lots of posts but I'm not sure if I am finding the right answer...
I'm trying to digitize several old camcorder VHS tapes. They were recorded in 1994 on a 1987 Magnavox S-VHS Camcorder (but these are standard VHS recordings). The problem tapes have video images that flip or roll vertically. You can see it on an analog playback and on the transferred digital image. I think the camera was out of alignment when they were recorded because I remember sending the camera away for repair.
I've tried using different VCR's, including the original camcorder to no avail. I tried adjusting the tracking while playing, too.
I purchased an AVT-8710 thinking that it would re-time the signal and maybe correct the problem. I think it may be improving things a little, but the image still jumps and rolls way too much.
Should the AVT-8710 fix this, or is there a better device? (Is the TBC-1000 better?) Should I try to manually adjust the VCR guides for better alignment?
Any advice would be appreciated. Thanks
	You should try one sample tape with a video duplication service and see what they can do. At the least they will explain what is wrong with the tape.
 The expert approach is to mis-align a playback VCR to the state of the record machine. Google Books (or your local library) has several books on VCR repair but there are minimim tools needed to adjust guides and tension and an oscilloscope to observe the RF waveform while making adjustments. The books will explain how to adjust a VCR to a known good standard tape. In your case you would adjust to the tape from the camcorder, make your dubs, then set the VCR back to correct specs to play other tapes. Alternately, a good VCR repair tech will know how to do this and have all the necessary equipment.
 Google books
 http://www.google.com/search?q=VCR+repair&btnG=Search+Books&tbm=bks&tbo=1Last edited by edDV; 19th May 2012 at 21:11. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  AG-1980: Vertical jitter with or without AVT-8710 TBC. Ideas?By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 10:31
  AVToolbox AVT-8710 TBCBy maeks84 in forum RestorationReplies: 3Last Post: 28th Apr 2008, 01:37
  Help with AVT-8710 TBCBy Reniamatic in forum RestorationReplies: 2Last Post: 17th Sep 2007, 16:26
  Panasonic e80h and the AVT-8710By rmmd in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Sep 2007, 14:03
  AV Toolbox AVT-8710?By hip_school_preppie in forum Capturing and VCRReplies: 4Last Post: 30th May 2007, 19:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
