i've ripped about 6 or 7 movies so far. i'm running a amd k6-2 450... i recently ripped saving private ryan...final size was 1.4gb resolution 640x352 and bitrate was 520kbps but when it was done it said average was 900kbps. i use dod speed ripper, flask 0.594, virtual dub and the divx 4 codec is installed. the quality is not what it should be at that size...and when i was encoding it there was only low motion and the divx 4 beta codec. no fast motion...any advice? or is there a better prog out there?
Results 1 to 1 of 1
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
