Hi,
Does anyone know which MPLS file to use for Warrior 2011, UK release?
There are many to choose from, and the correct one is not the largest; it repeats scenes.
Thanks.
	how about simply choosing the one where the playtime matches the playtime of the movie and the resolution specified matches the resolution of the movie?
	To be blunt, this is not a particularly popular film in the USA and you asked about the UK BD release, so both of those have basically eliminated the number of people who can help you to just our UK members who ripped the film and worked with only the movie. If I recall correctly, multiple playlists is one way to thwart people like you. I do have some suggestions.
 1) I do not know how many playlists there are, but you could just try them all until you get the one you need.
 2) What did you rip with? If you used anything other than DVDFab HD Decrypter or AnyDVD HD then I would suggest that you re-rip with the free DVDFab Passkey and see if you get different output that you can more easily work with.
 3) DBRebuilder is fairly intelligent about this kind of thing so you could just install it, make a movie only backup to BD-25 size and then use that output as your source for whatever you trying to do.
  How to remove a m2ts file in a mpls playlist ?By fdenis31 in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Mar 2012, 22:46
  Can I edit a BD playlist file (.mpls)?By badreligionhead in forum Blu-ray RippingReplies: 2Last Post: 6th Dec 2010, 20:06
  Bluray MPLS EditorBy xieliancheng in forum Authoring (Blu-ray)Replies: 1Last Post: 5th Jul 2010, 01:04
  Choosing correct mpls file HELPBy DravenJ in forum Blu-ray RippingReplies: 4Last Post: 8th Jun 2010, 08:49
  Multiple .mpls to choose fromBy sharjohn in forum Blu-ray RippingReplies: 1Last Post: 17th May 2010, 14:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
