Results 1 to 14 of 14
  1. is bigasoft mkv video converter good one to convert and join mkv to other formats without losing subs stylish and soft ?
  2. Member dragonkeeper's Avatar
    Jul 2003
    I wouldn't use it. Take a look at the tools section their are many tools that will do what you want from free.
    Murphy's law taught me everything I know.
  3. which will be good can you recomend me one ? without losing quality and subs from stylish subs and soft and others
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    What other formats?
    Format factory is one I'd recommend. It has lots of support and also does the following subtitles:
    srt, ass, ssa, idx
    Chances are if your subtitles aren't in one of these formats there is a separate converter program online that could convert it to one of these.
    Also if you simply need to remux (ie copy into another container) then you can try winff. I haven't done subtitle work with winff so I don't know how that works with winff but I'm sure it is able to do it.
    (Fyi depending on how new you are to digital video .avi, .mp4, .mpg, etc are just containers, they hold the video and audio, the codecs are what the videos are actually made of - ie h264 or divx/xvid and etc - those go INSIDE the .mp4 or .avi etc).
  5. i am trying to convert bakegyamon from mkv to mp4 or other small formats but with some i use it loses subs it says it has English styled English, Chinese, Malay VobSubssoftsubs
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Try mkvtomp4.
  7. to collect a few facts:
    1. mp4 does not support picture based subtitles (there's support for idx/sub subtitle on Nero chipset devices, but tha tnever made it in the standard)
    2. mp4 support ttxt subtitles which are just basic subtitles with not much styling infos in it
    1. if you convert from a picture based subtitle format you need to run OCR and then convert the output to ttxt (or srt if the multiplexer used supports it and internally converts to ttxt)
    2. if you use text based subtitles, these need to be converted to ttxt, but be aware that you will loose next to all styling informations
    3. you can't keep decently styled subtitles inside a mp4 container unless you hardcode them into the video
    Cu Selur
  8. i am now a little confused how to do.? i tried using mkvtomp4 adding video and then start after that i tryd playing video but it lost subs. i tried with format factory it did not lose subs but the video increased size. is there a programm that it will not lose subs and decrease size ?
  9. Member yoda313's Avatar
    Jun 2004
    The Animus
    You have to change the bitrate. Use a bitrate calculator to determine the proper setting for the file size you want.
    Also note lower bitrates will lower the quality of the video.
  10. for example i want it lower than 100 mbs original has 130 mb but after format factory it became above 400mb. or is there another programm to decrease without losing quality if can ? is there easy way ?
  11. or is there another programm to decrease without losing quality if can ?
    Your target format is a lossy compression so you will always lose quality
    is there easy way ?
    if the output was 400MB and you want to have 100MB instead you need to set the output bit rate to a quarter of it's current value, if you don't know the current value use i.e. mediainfo to get the current bit rate of the 400MB file,..
    (no clue how to use format factory, never used it, but I guess there is an option to set the output/target bit rate)
  12. i tried uploading a video on a site and it went deleted becasue of copyright. is there a way to upload videos even if they are copyright ? is there a programm for it to remove or something ?
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    I don't know if this would work but try naming the file video1 without the name of the video itself?
    I think they have audio watermark programs that can identify songs and such. I don't know if they have a similar program for video. Its possible they could be scanning the video for copyrighted images before uploading - I don't know if thats possible though for video.
    Try renaming the file to a generic name and see if that lets it through.
  14. do youn know dailymotion that is the site i tried with a video named bakegyamon but it was deleted i try later changing name like ya sayd.
