This is what worked for me:
TV: Sony KDL-32EX308
Software: Handbrake
OS: (shouldn't matter, but) Sabayon Linux 8
In Handbrake, I set the Codec to MPEG-4 (FFmpeg)
Use NTSC (29.97) framerate and set it to Variable Framerate.
Set the encode to Constant Quality and put the slider between 1 and 8. Setting 1 will be higher quality but larger filesize. If you source video is already a crappy bitrate, then a higher setting here will not help you. (you can't get something from nothing).
Make sure the filename stays .mp4 and NOT .m4v. I changed the default settings in Preferences to not use this.
My audio is set to AAC. I use 160Kbps Audio bitrate.
Results 1 to 1 of 1
Led tv 32” sony kdl-32ex42
By matrixnis in forum SubtitleReplies: 0Last Post: 6th Jan 2012, 09:41 -
How to play & convert Sony 8 mm Video 8 NTSC Tapes
By Richiegs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 19th Nov 2011, 22:13 -
Need Help with Sony KDL-32EX500 TV (Horizontal Banding)
By SONYex500 in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2011, 22:54 -
Sony Bravia KDL 52V4100 brightness issues
By jman98 in forum DVB / IPTVReplies: 8Last Post: 18th Mar 2009, 16:56 -
Sony KDL 26S3000 NTSC to Europe's PAL
By Konstan in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2008, 13:12
