So I just got my BlackMagic Intensity capture card working and got some gameplay footage. I tried finding some software that could help me cut down the file size so that I can upload my videos without having to take 1 hour just to upload a 11 second video. The ones that I've used so far just loose the quality and looks terrible.. Here is the quality of this video that I used without compressing http://www.youtube.com/watch?v=v2OS3lTYxHI&feature=BFa&list=UUxHm6aZ882OXR68UrG9c3nQ this took me just about near 2 hours to upload -.- someone PLEASE PLEASE help me >.<
You know, don't you, that YouTube reencodes everything you send? And if you want it to be available in high definition, then the files will be pretty big to begin with. If that doesn't matter, then lower the resolution. So, while they might look good when you upload them (do they?), they may not after YouTube gets done with them.
Anyway, it might help if you told us in what format you're sending them and how they've been encoded. If you don't know what they are, use MediaInfo on one. -
create a batch file to convert whit ffmpeg
for %%i in ("*.avi") do ("%~dp0ffmpeg.exe" -y -i "%~dp0%%i" -vcodec libx264 -acodec libvo_aacenc -ar 44100 -b:a 112k -coder 1 -cmp +chroma -partitions p8x8,b8x8,i4x4,i8x8 -me_method hex -crf 26.0 -subq 6 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 0 -qmax 69 -qdiff 4 -bf 3 -refs 8 -direct-pred 3 -trellis 2 -wpredp 2 -rc_lookahead 60 -threads 0 -ab 112k "%%~ni.mp4" & "%~dp0ffmpeg.exe" -y -i "%~dp0%%~ni.mp4" -vcodec copy -acodec copy "%~dp0%%~ni.flv" )
Can you save a video after editing without compressing?
By vid83 in forum Video ConversionReplies: 1Last Post: 2nd Feb 2011, 16:54 -
Compressing 30+ hours of video to 10 minutes?
By nerys in forum EditingReplies: 5Last Post: 8th Jul 2010, 05:49 -
converting/compressing video
By govtphish in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2007, 01:56 -
compressing a video
By Shotobits in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 11:18 -
Compressing DV video
By Duncan1382 in forum Newbie / General discussionsReplies: 14Last Post: 14th Jul 2007, 16:21
