When using a 32 bit OS some RAM disks can use memory beyond 4 GB.
Results 31 to 41 of 41
Point taken.You need to take more initiative if you want to build a PC. I suggest that you educate yourself on the basics of assembling a system from scratch, before you order anything. The instructions that come with the various parts can be a bit sketchy, and you shouldn't expect anybody here to write down complete, step-by step detailed instructions for you.
I will do some homework and post my build when I'm done before I buy to see if (read "what") I screwed up in my design.
Thanks -
Good point. But I imagine as a stop gap measure if you're saving up for a special pair it wouldn't hurt.Originally Posted by usually_quietDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Im not sure if this system is at all compatible or if it will meet my needs, but after surfing around trying to get this right this is what I came up with. Way over budget, and Id love to bring it down some without sacrificing my needs.
Again I am using this for:
- Online streaming (Netflix, Hulu, Youtube, Pbskids etc)
- HD Video viewing and storage (sometimes 1080p) (most will be stored on external HD after we watch first time)
- Picture storage and viewing, minor editing
- Home Video storage and viewing (no editing)
- Web browsing (facebook, news, etc)
Case $40 Couldnt find the case on Newegg thats why I went Amazon...
2.5 Hard drive 1 $100 Do I need separate SSD for OS?
Processor 4 core $120 is it compatible? Do I need it?
MB 1 $90 MB 2 $100
RAM 8 gb $60
Power port $53
Power Cable $10
Wifi Adapter $7.75
OS $97
It is low on HD space, I know, but I really love the small footprint of this case.
Biggest question would be heat issues I think, but I am hoping you guys can give me more insight if this will work...
Poke all the holes you can please
Thanks! -
No way! That case will not work with that motherboard and CPU. Anything with a reasonable amount of computing power will fry in a tiny case with no fan. ...and that kind of case would be total lunacy for a first time build, even if you had reasonable expectations as to what you could put inside it. Plus, 80W is not nearly enough to power the system. You picked a 100W TDP CPU and a high end motherboard. If a 200W PSU is borderline for the build I proposed with a 65W TDP CPU, how do you expect a 80W PSU to work for a 100W TDP CPU?
You cannot build a tiny PC similar in size to the Zotac barebones products, but with more power. It is not possible with current tech. If it could be done, Zotac would already be doing it.
[Edit]The E350 motherboard will theoretically work with the case, but its on-board CPU the same CPU used in some of the Zotac bare-bones systems. It will not reliably play video when the CPU has to decode it. The CPU is pre-mounted, so I don't think you could replace the CPU with a different one. I'm not sure about the PSU requirements, but 80W seems like it may still be too little.Last edited by usually_quiet; 30th May 2012 at 12:27.
You had some great suggestions I think you should pick one that is most likely to fit the needs and desires you have outlined and go with that. I don't thing the build you have proposed will do what you wish. I see you have included a wifi card I have trouble streaming 1080P video over wireless N. Not sure how it would work with netflicks as i have not bought into the hype.
Murphy's law taught me everything I know. -
Ouch... I had a feeling i was aiming too high but that was a big time no... Your points about the PSU and wattage make perfect sense now that you point them out...No way! That case will not work with that motherboard and CPU. Anything with a reasonable amount of computing power will fry in a tiny case with no fan. ...and that kind of case would be total lunacy for a first time build, even if you had reasonable expectations as to what you could put inside it. Plus, 80W is not nearly enough to power the system. You picked a 100W TDP CPU and a high end motherboard. If a 200W PSU is borderline for the build I proposed with a 65W TDP CPU, how do you expect a 80W PSU to work for a 100W TDP CPU?
Ok so would there be any build in that size case that would be able to do what I want it to do (seamless HD and seamless web etc)?
You also seem to think Im crazy for trying to do a first time build so small. And I take your advice seriously because I have a very minimal idea what Im doing.
But.
- I am crazy
- I watched quite a few youtube clips and it seems pretty straightforward.
- Id like the experience it will give me.
- Theres nothing pre-built out there thats small and does what I want it too.
The teeny-tiny case you are so in love with is designed for Intel Atom CPUs and AMD E350/E450 APUs plus their motherboards. (The motherboard comes with the processor already mounted on it.) We've already determined that Intel Atom CPUs and the AMD E350/E450 APUs won't work for what you want to do with them.
This is the most powerful itty-bitty system Zotac offers http://www.amazon.com/Zotac-Dual-Core-Barebone-System-ZBOXGIGA-ID70-PLUS-U/dp/B006P15U62
It uses the 35W TDP Intel Dual-Core i3 2100T Processor (2.5 GHz) similar to the i3-2120T I mentioned early in this thread. It has 4GB of memory, plus a 320GB HDD and would meet your basic requirements otherwise. It comes with everything but the OS included.
Could you build something like it yourself? That is hard to say. It sure would not be easy. Zotac can have some parts they may want custom made. You have to use all off-the-shelf parts. I already gave you my best recommendations for a decent smallish system built from more or less standard parts. I'm done here. Good luck figuring out something on your own.Last edited by usually_quiet; 31st May 2012 at 20:23. Reason: misplaced word
You are incredibly lucky. I found a kit suitable for an i3 build with a CPU up to 65W TDP at the website for another company selling the M350 case. Cable management will be difficult with such a small case, and heat build-up could still be an issue. As dragonkeeper said, wireless is problematic for 1080p video. A wired connection will work better.
Kit with Case, PSU, cables and motherboard:
$185 http://www.mini-box.com/KIT-M350-INTEL-DH61AG-19V-160W
CPU
$124 http://www.amazon.com/Intel-BX80623I32120T-Core-I3-2120T-2-60GHZ/dp/B005LMPN7M
HDD
$75 http://www.amazon.com/Western-Digital-AV-25-Cache-Drive/dp/B004SB8YQ4
RAM
$45 http://www.newegg.com/Product/Product.aspx?Item=N82E16820139482
OS
$100 http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
It looks like there is a place to mount one of these fans in the front of the case, but I'm not sure there is room for it once everything else is inside. There is a system fan header on the board you can use for it.
http://www.mini-box.com/Top-Motor-40x4010mm-Case-Fans
You theoretically could use this i3 CPU instead. It more powerful, and has better graphics but uses more power and produces more heat than a 35W TDP CPU.
http://www.amazon.com/Intel-BX80623I32105-Core-I3-2105-Processor/dp/B0051YS85O
You may need this if the stock CPU cooler is a bad fit
$35 http://www.mini-box.com/Low-Profile-LGA1155-Intel-Core-i3-i5-i7-CPU-Cooler
This is a remote kit that will work with the CIR header on the Intel MB, but I don't know where you could mount the CIR receiver in that case. There is no window provided for it.
http://shop.inteset.com/Products/13-4-in-1-backlit-remote-and-cir-receiver-wcable-and-...herboards.aspx
Mounting Options:
VESA back of TV mounting screws
$2 http://www.mini-box.com/Vesa-Mounting-System
VESA wall mount. Looks more secure but blocks some of the case's ventilation holes
$30 http://www.mini-box.com/M350-VESA-Display-MountsLast edited by usually_quiet; 1st Jun 2012 at 18:16. Reason: Forgot VESA screws for back of TV mounting
Advice needed for 1st time HTPC
By hanugro in forum Media Center PC / MediaCentersReplies: 19Last Post: 17th Mar 2012, 12:07 -
building an htpc for first time need some advise
By francisuk in forum Media Center PC / MediaCentersReplies: 10Last Post: 6th May 2011, 19:39 -
1st time HTPC - No drives in the case.
By Bronx in forum Media Center PC / MediaCentersReplies: 10Last Post: 15th Sep 2008, 12:27 -
Do you have a htpc?
By yoda313 in forum PollsReplies: 26Last Post: 22nd Aug 2008, 21:16 -
To HTPC or Not to HTPC
By Bondiablo in forum Media Center PC / MediaCentersReplies: 8Last Post: 22nd Oct 2007, 04:50
