What program should i use that resizes faithfully and with minimum loss (any particular agorithm to be chosen like bicubic or nearest neighbour)l my extracted VCD dayt video files
Shall i retain the dat/mpg 1 format or change format also (which format is best) in the process
any advice or precautions or settings i need to worry about
				Results 1 to 12 of 12
	Resize for ??? resolution? What?
 You will save in hardisk or other media?
 Try avisynth scripts or Virtualdub to resize resolution.
 Claudio
	Last time I resized up from VCD to DVD I used VirtualDub and frameserved over to MainConcept.
	I agree nnedi3_rpow2() is probably your best bet. But VCD usually has a lot of macroblocking so you'll want to deblock before upscaling. You can also look into Video Enhancer.
 On the other hand, why bother? Most DVD players or HDTVs will do a fair job of upscaling the original VCD. Usually a bicubic filter. Not as good as nnedi3_rpow2() but not a huge difference. DVD players can play the MPEG 1 video from VCD. You just need to convert the audio from 44.1 to 48 KHz.Last edited by jagabo; 18th May 2012 at 08:18.
	Except a lot of recent model DVD players, and many BD players, no longer play VCD (though they may still play plain MPEG1 files), so the idea of doing a conversion beforehand may not necessarily be the 2nd choice.
	Mpg1 is dvd compliant so no need to convert if you are going to author as dvd video. I think,therefore i am a hamster.
	Yes, but...
 Few authoring programs accept it. I have a test DVD that I made containing only MPEG-1 video (it's at valid resolutions and bit rates for DVD) and I had to use Scenarist to make it. That would not be a realistic option for most of our members.
 It would not surprise me if a small number of manufacturers no longer support even valid MPEG-1 in DVDs as I think the only place I ever saw it used was on some Russian DVDs I have where it was used for a short studio logo clip.
	I do quite a few conversions from VCD to 720x480 for DVD. Like already mentioned, nnedi3 is about the best upscaler in the AviSynth world at the moment. And that's after deblocking and noise removal along with other kinds of cleanup of the original crap MPEG-1 file. Then after the resize I'll sharpen.
  Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid fileBy GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23
  Anyone know of a good MP3 program to resize (make smaller) some filesBy soulbug in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2011, 16:03
  VCD dat filesBy mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50
  Creating video files larger than 1 GB with mencoder, important hintBy penguin74 in forum LinuxReplies: 1Last Post: 4th Nov 2007, 21:13
  Extracting jpg photos from the ITEM####.dat files in the VCD segment folderBy H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
