  1. Member RogerTango's Avatar
    Nov 2007
    Ive got a really nice JVC HD camcorder, but... as time has gone by, Ive learned terms like "rolling shutter", and "Jello Cam".
    Was wondering if there was a list somewhere that detailed the consumer/prosumer HD cameras that have CCD sensors.
    The only ones Ive been able to find were pro level, $4K and up.
    Looking for something in the $400 range.
    Thanks for any URL to list, or suggestions.
    Cheers,
    Andrew
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Nope none nada for HD.
    http://www.kiva.org/about
  3. Member RogerTango's Avatar
    Nov 2007
    I forgot to mention, it needs external mic connection...
    But from your follow up post, and my googleze, Im finding that out...
    Sigh...
    Thanks for the post friend!
    Andrew
  4. Member edDV's Avatar
    Mar 2004
    You can find SD 3x CCD under $1k if you shop eBay or Craigslist.
  5. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    Cheers,
    Andrew
    The Panasonic HDC-H9 if you can find older stock or 2nd hand.
