    Mar 2012
    United States of America
    Hello I have a issue that I would like to resolve. I have one of the very first versions of the Blackmagic Intensity capture cards Name:  blackmagicintensity.jpg
    It has 2 HDMI ports and no break-out cable slot like the Blackmagic Intensity Pros. My issue is that I play on a monitor and the monitor has 1 VGA port and 1 DVI port. I use a DVI to HDMI cable to hook up to my Xbox 360, so I have no extra HDMI slot on my Xbox 360. Is the only way for me to get this to work would be for me to just buy a HDMI splitter?? If so please send me a link to a excellent HDMI splitter cable that you use that works great for you also if you did this same set up I'm trying to do am I missing anything that I also need rather than a HDMI splitter? I'm a newbie to this so sorry if I asked a dumb question. Thank you.
    Mar 2012
    Okay I got it figured out Problem solved!
