Hi - does anyone know how I can export to this exact format? I can get almost there with Adobe MC, Telestream, Vegas, etc - but cant get the "closed GOP every GOP" sorted.
Would FFMPEG do it? If so - how the hell do I use it? :/ Will pay for someone to set it up for me.
“Wrapper”HD File Delivery Specification
MXF OP1A
Video CODEC
XDCAMHD 422
Frame Rate
25 frames per second
Video Format
1080i25, interlaced, top field first
MPEG Profile
MPEG-2 422P@HL
Resolution
1920 x 1080
GOP
· 12 frame GOP
· Closed GOP, every GOP
· GOP header on every sequence
· Sequence header on every GOP
Timecode
· TC in every GOP header
· Timecode to start from 10:00:00:00
Intra_DC_precision
10 or higher
Bit Rate
50 Mb/s Constant Bit Rate
Audio Format
· 24 bit depth
· 48 kHz sampling rate
· PCM
Audio Range
· Peaks -9/10dBfs (6ppm)
· Average Dialogue - 16dBfs
· Average Music -12dBFs
· Low level - 24dBS
Audio tracks 1&2
Stereo English Language
Results 1 to 1 of 1
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 16:29 -
Convert files into a lower GOP format?
By Coroni in forum Video ConversionReplies: 3Last Post: 25th May 2010, 19:33 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14 -
finding GOP header by opening a file in binary mode
By VBMizio in forum ProgrammingReplies: 1Last Post: 30th Aug 2007, 07:38 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 9th Jun 2007, 00:08
