    Feb 2008
    Singapore
    Hi,
    I was recording a video yesterday on my laptop using a software called YouCam.
    Unfortunatley my laptop battery ran out of power while recording a clip and im unable to play the file now.
    Can anyone please recomend a program that will enable me to play an incomplet avi / un properly saved one?
    THe file size itself is around 10GB so it captured almost everything.
    I have tried playing it on VLC, GOM, Windoes Media Player and used AVIcodec to see its specific details but nothing works/
    AVIcodec is saying: Opening Error Cant play back the file. Format is not supported.
    Thanks for the help
  2. Hi,
    VLC has a "rebuild AVI index" feature that sometimes work. It's buried deep inside Preferences, under Inputs/Codec -> Demuxers -> AVI.
    Force Index Creation: Always Fix
    You can also have some success with MPlayer (on Mac, MPlayer OSX Extended is recommended).
    If nothing works, you should try video repair tools.
    This one should give a preview directly in your browser. No need to install software
    http://mp4repair.org
    -- Benoit
    Feb 2008
    Singapore
    thanks very much. Will test them all out now.
