Gang,
Help me out here a bit. I am currently using VirtualDub with either Huffyuv or PICVideo to capture AVI and apply various filters. Then I frameserve to TMPG. Quality is outstanding, but TMPG is SLOW SLOW SLOW!!!!!
I am thinking about LSX to do my encoding. My question is, can you frameserve from VirtualDub to LSX? If so can someone give me instructions how to or resource to use (that is if it is deifferent from VDub to TMPG)? If it is the same as TMPG, just let me know. Thanks.
The only difference with LSX is that the dummy file (VDR) created by VirtualDub must be created with a .AVI suffix. Once you do that, LSX works fine.
Have fun,
Ian -
The only detail that you need to pay attention to with LSX is that it demands that its input file must end in .AVI
When you create your VDR file in Virtualdub, just add .AVI onto the name and you're away.
Have fun,
Ian -
Thanks Ian, it is just the same as TMPGEnc. With a file such as *.vdr.avi
Great, much appreciated
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
which mpeg-2 encoder would you choose...
By deadrats in forum Video ConversionReplies: 28Last Post: 12th Nov 2009, 22:11 -
mpeg encoder for DSP
By mourya in forum ProgrammingReplies: 2Last Post: 31st Oct 2008, 11:28 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:39 -
The best DV AVI to MPEG-2 Encoder for me to use.
By leegutcher in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 07:54
