Hi,
I'm using Adobe Premiere Pro CS6.
Does anyone know how hack one of the export file presets? I can open the preset files (.epr) in Notepad, but I have no idea what to do from there.
Basically - I want to add an extra 'rule' to one of the preset files. It's the MXF OP1a, HDCAM422, 1080i preset - I want to set it to Closed GOP, every GOP. Currently it doesn't have this option.
I can pay someone if they can add this feature to that preset for me.
Thanks.
i'm pretty sure the hd422 standard is fixed and allows no changes to the long gop structure. or much of anything else.
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 01:05 -
is there anyway to export from Adobe After Effects CS5 to H.264? or other?
By Onceler2 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 16:59 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 18:45 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 16:29 -
FLV Import/Export Nellymoser audio - Adobe Premiere CS4
By shagen in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 18:38
