Hi there,
I'm trying to encode a video with Ass subtitles by using StaxRip, but everytime the final result is a video with subs in Arial, no colors, nothing.
There is something that maybe I don't have: plugin or a filter? Or there is no way to encode Ass subs with this program?
If I remember correctly StaxRip is using AviSynth as a frameserver so it should be possible (at least if you write your own AvnSynth Script).
You need a subtitle renderer possible to render ASS Subs (I'd recommoned you assrender since VSFilter is really slow sometimes but this will make things a little more complicated so you may want to stick to VSFilter), the subtitle script and the fonts used by the script (otherwise it will fallback to Arial which may happened to you).
You may check if you got all needed fonts using the Aegisub "Font Collector" feature. You could also use aegisub to change the fonts and other style properties if you'd like to.
An example for writing your own .avs would look something like this:
You may then load this avs file as the source in staxrip.Code:# if you want to use assrender LoadCPlugin("path/to/assrender.dll") # for vsfilter LoadPlugin("path/to/vsfilter.dll") # you will need this in both cases - it opens the video directshowsource("path/to/source.ext") # render subs with assrender assrender("path/to/subs.ass") # or render subs with VSFilter TextSub("path/to/subs.ass")
I hope I could be of any help but first check if the fonts are even installed.
.ass subtitles encoding help
By B Boy Rock in forum SubtitleReplies: 6Last Post: 16th Aug 2010, 14:02 -
Hardcoding ASS Subtitles
By roflwaffle in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2010, 15:45 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
DVD(video) + .ass subtitles?
By andy_blah in forum SubtitleReplies: 4Last Post: 20th Jan 2009, 12:28 -
.ass Format Subtitles With .wmv?
By NeoCyrus in forum SubtitleReplies: 4Last Post: 26th Nov 2008, 21:14
