I have been using a Kworld card on my old computer.
It doesn't seem to work with my new computer - Windows 7 Professional.
Looking for suggestions for a reasonably priced card to use with Media Ctr to record to hdd.
Any advice appreciated.
Results 1 to 13 of 13
Do you need an analog tuner (for analog cable) or a digital tuner (for use with an antenna or clear QAM cable channels)?
[Edit] Also, what kinds of interfaces do you have available for installing the new tuner? USB 2.0? PCI? PCI-e?Last edited by usually_quiet; 15th May 2012 at 18:32.
I have a digital tv and only over-the-air antenna.
My computer specs are next to my name.
I'll try to give you any other info if you need it.
(4 pci slots)
This is the computer : http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2406874&Sku=B69-1407Last edited by Psco2007; 15th May 2012 at 22:51.
The motherboard included in that kit has 5 PCI-e expansion slots and two PCI expansion slots. I will assume you still have an open PCI-e slot.
I have had an AVerMedia HD Duet White Box installed since September of last year. http://www.amazon.com/Avertv-MTVHDDUWB-Duet-White-Box/dp/B00266P6G4
The first one died after a month, and I RMA'ed it to AVerMedia. Customer support was OK to deal with. The replacement they sent has been going strong since November. The tuners are good for a PC TV card and having two is convenient. It works well with Windows 7's Media Center. Since it doesn't come with (or work with) AVerMedia Center and doesn't include a remote, the White Box version is less expensive than the retail version.
If you only need one tuner, the AVerMedia AVerTVHD Bravo costs a little less.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100042&Tpk=N82E16815100042
Either download drivers from AVerMedia's website or let Windows 7 find them. These two TV cards only provide ATSC/clear QAM tuning. There is no analog tuner and there are no analog capture ports.Last edited by usually_quiet; 16th May 2012 at 00:19.
Can you explain the difference between the PCI -E and PCI?
Thanks -
PCI is older and provides less bandwidth than PCI-e. Wikipedia can explain the technological details better than I can.
Your motherboard manual should have a diagram showing which expansion slots are which. The TV cards I suggested are PCI-e x1, but should work in any of the other types of PCI-e expansion slots found on your motherboard. -
http://www.google.com/search?q=pci+%26+pcie+pics&hl=en&rls=com.microsoft:en-us:IE-Addr...w=1280&bih=893
pics of pci & pcie & pcie2 -
Thanks - appreciated.
Any suggestions for a good card in the $100.00 range? -
If you don't need analog at all, and have a home network, the Silicondust HDHomerun gets a lot of good reviews, and the tuners can be shared by other computers on the network running Windows 7. http://www.amazon.com/SiliconDust-HDHomeRun-Definition-Television-HDHR3-US/dp/B004HO58SO
The Hauppauge WinTV HVR-2250 is another good dual tuner option with analog support.
http://www.amazon.com/Hauppauge-1229-WinTV-HVR-2250-System-Builders/dp/B001E2T6Y4 -
[QUOTE=usually_quiet;2162808]If you don't need analog at all, and have a home network, the Silicondust HDHomerun gets a lot of good reviews, and the tuners can be shared by other computers on the network running Windows 7. http://www.amazon.com/SiliconDust-HDHomeRun-Definition-Television-HDHR3-US/dp/B004HO58SO
This unit seems nice, although I would have preferred an internal card.
Thanks for the advice.
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
TV Tuner card for use in Japan
By schwarznavy in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2009, 03:43 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
I use these programs for my tv tuner card
By Milardo in forum Capturing and VCRReplies: 5Last Post: 17th Jun 2008, 05:28 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
