Or is it impossible for PS3s without OtherOS?
If you've updated your ps3 or buy a new one (within the last year or so I belive) the other os option is no longer available.
So far as i know that was the only way to do it was with linux.
There might be a way to downgrade the firmware to the early versions that had it. If you really want to check online for ways to load old firmware on to the ps3. However you would not be able to use it online with the official sony services without upgrading the firmware which eliminates that feature.
One possible alternative is to do realtime capturing. You can do it with the hauppauge hdpvr and component cables however you will only be able to do dolby digital tracks as it doesn't encode dts.
You are better off using a computer bdrom drive for ripping. Dvdfabdecrypter has a free ripper but isn't updated as frequently as the pay version is (but its still updated just delayed). Then there is the payware anydvdhd that works with bluray as well.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
As far as obtaining a bit perfect copy yes you are 100% correct.Originally Posted by jman98
I'm just trying to throw out as many options as possible for the poster.
I'm sure there are people that try capping high def in standard def. Remember people do weird stuff
But I've gotten pretty good results doing that sans the dts limitation. In fact I dubbed a few of my hddvd discs that way with my xbox 360. Realtime is not ideal but is quick and dirty if you have a slower computer and don't want to do hours and hours and hours of encoding.
I do agree ripping is the best option but there are alternatives.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
ripping a blu-ray disc via ps3/linux?
By iThinkYouBrokeIt in forum Blu-ray RippingReplies: 1Last Post: 12th Feb 2009, 02:22 -
Anydvd HD and ps3 blu-ray discs
By JoeyGarbs in forum Blu-ray RippingReplies: 1Last Post: 15th Oct 2008, 20:57 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
Blu-Ray rip and stream to PS3
By bytre in forum Blu-ray RippingReplies: 2Last Post: 26th Mar 2008, 20:15
