I am trying to convert files (FLV, MP4) to AVI files with a result that's a certain file size. I have been using XMedia Recode with Win XP for my conversions. I have adjusted the bitrate and used their built in calculator, but it usually hit and miss.
Does anyone know of a calculator that gives consistent results?
Regards...John
The problem probably isn't in the calculator. It's more likely the codec isn't delivering the requested bitrate.
Either that, or the codec is set to go the CQ route instead of the VBR route.
Scott -
I know I'm asking to be shot down in flames, but I've never understood why people need a 'calculator' to multiply or divide two numbers. Don't they teach basic arithmetic in schools any more?
OK, I know it's the 21st century, and I can see the merit in a program that works out bitrate and/or filesize accounting for all of video, audio and muxing/container overhead, but for most purposes that level of accuracy is unnecessary and the basic calculation can be done in a few seconds on a piece of paper, using the well-worn mantra
filesize = bitrate x running time
Now, where did I put that abacus...
Another thing that confuses people sometimes is that microsoft likes to express file size in geek speak. Ie. when they say 1 K it's actually 1024 ... 2 to the 10th power.
Yes, to a disc manufacturer 1 GB = 1000 * 1000 * 1000 bytes, 1,000,000,000 bytes. To Microsoft Explorer (and many software packages) 1 GB (more properly called GiB) is 1024 * 1024 * 1024 bytes, 1,073,741,824 bytes. So a 4.7 GB disc only holds 4.3 GiB of data.
Video resolution (image size) calculator
By headless chicken in forum MacReplies: 10Last Post: 15th Jan 2011, 18:17 -
Audio File Size Calculator
By onesikgypo in forum AudioReplies: 1Last Post: 13th Sep 2010, 10:14 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 19:24 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 22:59
