I'm looking to trim part of a movie, and I want to be able to make sure they subtitles sync up properly afterward. How can I either edit a .sup file ripped from bluray, or change the timing of it in an MKV?
The following work flow would certainly do the trick:
1) Convert SUP to SRT.
2) Edit SRT in any text editor to remove the parts you don't need. You really should be able to figure out how to do this as soon as you open the file. SRT format is really understand to understand.
3) Make your new MKV with the SRT file. -
Is this possible to do without converting the PGS subtitles to SRT or anything else using OCR? I do not want to go through the process of teaching a program to recognize characters, then have to deal with the misreading of lowercase L and I. I just want to cut 1001 milliseconds from the start of a stream and re-save it again.
How add a subtitle to a bluray disk and then convert from 50 GB to 25 GB
By siopilos in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Feb 2012, 10:49 -
Converting bluray movie files to low size files
By AndreL in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 02:06 -
Subtitle problem when decrypting bluray
By adamf154 in forum SubtitleReplies: 7Last Post: 19th Jul 2010, 19:03 -
Bluray Subtitle Confusion
By Mr Flibble in forum Blu-ray RippingReplies: 10Last Post: 26th May 2010, 11:14 -
Modifying headerinformation in aac *.m4a files
By chh in forum AudioReplies: 4Last Post: 18th Jul 2009, 12:47
