I'd like to be able to automate my video conversions. I need to convert a lot of h.264 MP4 videos to Xvid AVI. I'm trying to set it up so a folder is monitored and the videos are automatically converted.
I've tried the old Handbrake 0.9.3 (last version with xvid) and DropFolders. I use this string and DropFolders tells me it's and invalid codec.
-e xvid -E lame -2 -s 175
I tried using HandbrakeCLI directly and it looks like it's going to do it but then gives me a bunch of exception errors. I'm assuming it needs the MP4 to be demuxed first?
I've been using this batch script to run avidemux2_cli, but I hate having to move all the files around myself.
set avidemux="D:\Locked\Programs\avidemux_2.5_r7200_wi n32\avidemux2_cli.exe"
set videocodec=Xvid
set audiocodec=MP3
for %%f in (*.mp4) do %avidemux% --video-codec %videocodec% --audio-codec %audiocodec% --force-alt-h264 --load "%%f" --save "%%f.avi" --quit
Problem is, I'd like to have the AVI files be the same file size as the original MP4s, but apparently avidemux2_cli doesn't support setting a target file size.
If you use 2pass encoding you can set target file size,
Code:--video-conf cq=q | cbr=br | 2pass=xx Select the encoding mode: constant quality (cq=quality), constant bitrate (br=bitrate) or 2 pass mode, in that case, give the final size in megabytes.
Thanks. That looks like it's doing the trick.
Now I just need to move the original file to a different folder after it is converted so I can keep originals around in case something goes wrong. How do I get the batch to do that?
Even more awesome, maybe there's a way to have the batch move the original to a different folder and also check that same folder for older files and delete them? Say, delete all files that are a week or older. -
Turns out, --video-conf 2pass=175 resulted in a file that was 196MB. That doesn't work for me. I wish it worked like MeGUI and other apps and took the audio size into account.
Looking at MCE-Buddy, it looks like it can't convert to MP3 audio, just AC3. I don't like that, but I might be able to live with it. Also, it doesn't allow for setting a target file size. Unless it all can be done by modifying the profiles it uses.
Plus, I can't tell how to set it to run in the background. Unless it does that automatically and doesn't show any evidence of it.
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 11:41 -
How Can I convert avi(xvid) to ipod tv out (H.264)?
By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 10:27 -
How to convert AVI to MP4 using H.264 encoder without losing video quality
By VidHunter in forum MacReplies: 0Last Post: 21st Dec 2007, 01:04 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 10:11 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
