The content of the original DVD shows what appear to be subs added direcrly from the disk and there is no setup involved. The run defaults to English subs.
I am using an older version of DVDFab and have had a lot of problems adding subs which should be simple to do int his program.
Process:
I select Generic
Main file is highlighted and 2 subpictures Eng and French are offered.
I untick the French and the Eng sub has a check.
But playback contains no subtitle. Where is my error?
Please say where the sub information appears on the process screen (where sound, track number and other things show up.) If a subtitle is selected should it appear in that window before Start is selected? Should an option other than Generic be used?
I noticed that selecting program only would not work since the time estimate was way too short. These are all confusing things for a program that performs well as long as no customization is needed.
I think I should have said 'please say *if* the subtitle infdormation shows on the process screen. The process screen is what appears with the info on single pass, track number, sound quality AC3 etc.
I have seen DVDFab's manual as well but they seem to be showing some redesign in a different edition where there's a dialog box that says 'force sub title' (check or uncheck).
What would be helpful is if a reader here who actually uses DVDFab and is getting subs to display would give a reply. That appears to be the only solution.
DVDFab MKV subtitles
By evt in forum Blu-ray RippingReplies: 9Last Post: 9th Dec 2013, 10:43 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 15:09 -
Adding DVDFab AutoPlay Handlers for Vista x64
By TooLFooL in forum DVD RippingReplies: 1Last Post: 26th Mar 2009, 05:12 -
DVDFab and subtitles (getting black square at top left)
By respondtome in forum DVD RippingReplies: 2Last Post: 3rd Apr 2008, 08:53
