I want to archive my Mini DV's onto my computer. What id like to archive is to get them onto my PC without any loss to the quality. I am aware that the size can be quite large so I will be keeping the archives on a external hard drive in their entirety, from there I will edit and put onto DVD as needed. So what is the best software to do this either free or purchased, I am not to fussed if I had to buy the software if their was to be a noticeable difference. The Mini DV would be transferred from the Camcorder via firewire to the PC.
Cheers
MiniDV to PC via Firewire is more like a "data transfer" than capture. There should be no difference between programs.
Free WinDV is all you need for a bit identical transfer from tape to file on the PC. Firewire transfer is a data stream to file process, not a file copy so it is possible to have frame loss. For this reason it is best to transfer to a drive that is not subject to OS interrupts (e.g. a second internal PATA/SATA drive). If you are using a single drive laptop, turn off anti-virus and other OS background tasks.
http://www.kiva.org/about
Hardsub HD AVIs without quality loss?
By zf1223 in forum SubtitleReplies: 3Last Post: 2nd Apr 2010, 17:34 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 15:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 12:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03 -
Transferring Mini DV to DVD without loss of quality
By khalidizzeldin in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 07:10
