    Dec 2009
    Russian Federation
    I have converted DVD to avi (Xvid).
    I use Media Player Classic to watch the video, it displays the resulting .avi in somewhat faded colors comparing to the original DVD:
    Origin - left, Result - right (normal printscreen was not available)
Name:	Photo 13.05.12, 1 11 25.jpg
    But, if I change ffdshow settings, the the colors are becoming normal: the change is to set RGB32 as the primary output colorspace:
    Probably, doing so is a bad practice.
    I suppose, I commit some mistake when converting the video.
    Next, I describe how I've done the conversion:
    Open the DVD's .vob in VirtualDub, do convertion using Xvid codec (full processing mode). All params are left to the defaults.
    So nothing special.
    Don't you see what can be wrong ?
    Lastly, I give the two videos characteristics:
    ------***origin - .vob***-------
    General
    Complete name : X:\VIDEO_TS\VTS_06_1.VOB
    Format : MPEG-PS
    File size : 1 024 MiB
    Duration : 24mn 39s
    Overall bit rate : 5 807 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Duration : 24mn 39s
    Bit rate : 5 300 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.512
    Stream size : 936 MiB (91%)
    Color primaries : SMPTE 170M
    Transfer characteristics : SMPTE 170M
    Matrix coefficients : SMPTE 170M
    Audio #1
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Muxing mode : DVD-Video
    Duration : 24mn 39s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 33.9 MiB (3%)
    Audio #2
    ID : 189 (0xBD)-129 (0x81)
    Format : AC-3
    Duration : 24mn 39s
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Text #1
    ID : 189 (0xBD)-32 (0x20)
    Format : RLE
    Format/Info : Run-length encoding
    Text #2
    ID : 189 (0xBD)-33 (0x21)
    Format : RLE
    Text #3
    ID : 189 (0xBD)-34 (0x22)
    Format : RLE
    Text #4
    ID : 189 (0xBD)-35 (0x23)
    Format : RLE
    Text #5
    ID : 189 (0xBD)-36 (0x24)
    Format : RLE
    Text #6
    ID : 189 (0xBD)-37 (0x25)
    Format : RLE
    ------***result - .avi***-------
    General
    Complete name : C:\Documents\DVD2Avi\prj\src.avi
    Format : AVI
    File size : 514 KiB
    Duration : 2s 236ms
    Overall bit rate : 1 885 Kbps
    Writing library : VirtualDub build 32593/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 2
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 2s 236ms
    Bit rate : 1 850 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.179
    Stream size : 505 KiB (98%)
    Writing library : XviD 64
  2. You cannot use 2 media players with graphics card overlay simultaneously to test accurately, the 2nd will use different renderer, usually resulting in faded colors, different levels
    When using vdub to convert use "video=> fast recompress" to make sure you don't undergo RGB conversion
    Dec 2009
    Russian Federation
    Thank you very much for the reply !
    1) >> You cannot use 2 media players ... to test accurately
    ok, but the result is the same when I have only one player launched, exited vdub, etc.
    2) And, especially, colors become normal should I only change that "primary output colorspace" ffdshow setting, I've talked about in the previous post. So, I guess, the "fast recompress" won't help here.
    3) also, when I use VLC player (which does't use ffdshow) colors are ok, when disable ffdshow for "XVID" FOURCC - colors ok in MPC player too.
    So, I suspect, that some info in the resulting video tells ffdshow to use wrong/unnecessary color conversion.
    Or it's something else, what do you think ?
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Which version of ffdshow are you using?
    Dec 2009
    Russian Federation
    I've recently reinstalled it, so I suppose it's fresh:
    main version:
    modules:
