I ripped a blu ray disk into my hard disk using DVD Fab 8 free version. I got the files in sub folders BDMV and Certificate. My question is, how can I make a backup of the movie in a BD25 ? (the movie will fit easily in the disc) I am afraid to do this by trial and error due to the expensive recordable BD disks!
I have all the hardware required to do so. That is not the issue.
Results 1 to 16 of 16
It is unclear from your post whether you are saying that you ripped a single layer BD disc (These do exist as some foreign films and films with no extras may only be on single layer commercial BD discs) or that you ripped a dual layer BD disc but just the film will fit in a single layer BD disc. If it's the latter, johns0's link will not help you. You will need to install and use BDRebuilder to pull the movie out of your rip into proper BD compatible format before you try to burn it.
The op did say the files ripped to a BDMV folder so there's no need to use BDRebuilder unless the folder is bigger than 23.3 gb,25gb isnt the true size of the bd-r disc as most people here know.
Thanks for the reply. I will have a look at it.
I said it will fit on a BD25. total ripped files size is 20.6. -
He only said that the film itself would fit on a BD-25. He did not specifically say that the entire rip was that size. Being a mod you know as well as I do that many people come here and inadequately describe their true situation. I was just covering the bases in case he was one of them.
Worked! Thank you all for your support. That was the first step and the easier one. Now on to a BD50 to BD25. Thats when BD rebuilder is needed. I've been reading some guides and following the steps but there is a "little" problem. I installed avisynth and when start BDRB it does not recognize avisynth.
BD rebuilder requires a specific version. Check the authors thread,you can get the correct version there. BD reuilder includes a file called inspect.exe,double click it and it shows the status of the program.
BD rebuilder version 0.38.02, avisynth 2.5.8. Inspect shows it as 2.5.8.0 and says it's ok. Yet BDRB does not run. I am usin a guide at DVD-Guides.com
If you have Vista or Win 7 you must run BDRB as Administrator at least the first time you run it. I do not know about XP. If you have not been running it as Administrator and have Vista or Win 7, try that. If you still have errors, post the error here. The download site is hosted on doom9.net and it is absolutely critical that you follow the instructions there when trying to set it up for the first time.
Running windows 7 professional as administrator. Message is "Program must abort. BD Rebuilder requires Avisynth to work." I've also followed dooms guide it has always given me this same error.
You didn't do something right when you installed Avisynth then. You need to focus on that. This page contains some brief installation instructions including telling you where to copy a dll file. That may be your problem. Put it where it says to put it for XP (it's the same for XP, Vista and Win 7).
http://neuron2.net/LVG/software.html
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Can I use MKV Files to burn on Blu-Ray?
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Mar 2012, 03:10 -
Help, can't convert or view VC-1 files ripped from Blu Ray
By Y2Bogus in forum Video ConversionReplies: 4Last Post: 12th Jun 2009, 06:29 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 20:51 -
Blu-ray ripped files to hard drive in Folders not un ISO Image
By judgmentday in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2008, 15:26
